Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Powerstroke Interior Discussion
  #21 (permalink)
Old 11-06-2008, 06:14 PM
winchester33 winchester33 is offline
cool. i forgot all about that post. that looks pretty cool. i was thinkin about getting a hidden winch behind the bumper but im not for sure yet.
  #22 (permalink)
Old 11-06-2008, 06:25 PM
JBHT JBHT is offline
There's so much stuff crammed in there, there's no room for a winch unless you bring the bumper way out front. That can be done but for me , I like as much ground clearance and approach angle as I can get.
  #23 (permalink)
Old 11-06-2008, 06:40 PM
there's a kit you can buy from warn that will allow you to fit a winch behind the bumper, but im not in a hurry to get it
  #24 (permalink)
Old 11-06-2008, 06:53 PM
spayne1976 spayne1976 is offline
Send a message via MSN to spayne1976
Rear seats
Man am I ever jealous of you guys. My 2002 has the older style bench seat where the base is just fixed. Are they compatible to switch them out if I can find a used rear seat from a newer model year? What year did they switch to that style of rear seat?
  #25 (permalink)
Old 11-06-2008, 06:59 PM
my cousin asked me the same thing, i didn't have answer for him either. Maybe start a thread and ask if its possible. or go ask a ford dealer, im sure they know if it has the same bolting pattern. if it doesnt, im sure you can rig up something yourself
  #26 (permalink)
Old 11-29-2008, 11:42 PM
STEVONATOR STEVONATOR is offline
This would be a great aftermarket idea. This is the one weakness that this rig has over my Dodge Ram. My 04 Ram had great storage compartments under the rear seat and I miss that. I am able to cram my chains and jumpers behind the seats of this rig, but thats all the room there is.
  #27 (permalink)
Old 12-07-2008, 03:37 PM
A8050266 A8050266 is offline
Send a message via AIM to A8050266 Send a message via MSN to A8050266 Send a message via Yahoo to A8050266
all,
I am currently building my own rear seat storage box.
Ill post some pics. its underway at this point as in I built half of it this week end.
I may have the box done by Monday. Ill pic and post tomorrow.
BTW My ride is 4dr with that heinous fold out lead weight contraption (removed)
till then.
  #28 (permalink)
Old 12-08-2008, 03:08 PM
BEWARE this thing is UGLY in this stage.
but I promise you once Im done covering it you will be AMAZED!!!!
so get a good look at it now.
Ok here is the box
in the pre carpet stage. (Ill post carpeted pics tomorrow)
a quick how to. goes like this.
Make a mold of your floorboard , steps, Tape up your carpet area (where the mold will be) tape it using 2" masking tape do this both ways then using some cheap spray glue
glue a layer of (garbage bag material) thin visqueen, drop cloth, this will be the mold release. then get out your fiberglass put down some mat and woven till your happy.
wait to dry then remove for trimming.
Build your access door I used 3/4 inch plywood 8 layer stuff. I cut the doors so that
I would not need a hinge, also I left plenty of play for the carpet.
Then I rigged the top piece to the bottom piece using some temporary wood wedges.
once the upper and lower pieces were in alignment. I wrapped the 2 pieces with some
fleece. (basically a baby blanket or similar) once i was happy with the shape I used
fiberglass resin to saturate the fleece into shape. wait to dry then trim.
Also I installed a few braces for strength .
Once dry Grind to smooth and go get some carpet. (dont forget to trial fit many times....)
see pics below.
while doing this keep in mind how you will want your access lid to turn out.
this is installed side view (again NO CARPET YET)
view from front looking back
looking in from Drivers rear door
close up of door countersink
nice side view from psg side One seat down one seat up.
Now some out of the truck views
the whole box with doors
the underside basically the mold of the rear floorboard.
A close up of my internal gussets/aka braces
  #29 (permalink)
Old 12-08-2008, 05:53 PM
Nice job !
I love the pajama lookin cloth !
  #30 (permalink)
Old 12-08-2008, 08:05 PM
BigIslandBoy BigIslandBoy is offline
That's gonna awesome when you are done. You should make a mold and pop some out to sell others. Hint. Hint. I would buy one from you. Great job keep us posted. TIA
