Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Powerstroke Interior Discussion
  #11 (permalink)
Old 10-30-2008, 10:22 AM
danno danno is offline
Does anyone here know where to tap into the factory dash light circuit for lighting aftermarket gages on a 2008? I keep hitting dead ends on this issue where ever I look.
I put a single gage pod in my F450 and painted it to match and Wow it looks great except for the lighting
Dan
  #12 (permalink)
Old 11-04-2008, 06:59 AM
Cody6405 Cody6405 is offline
The best palce to tap into for your light source is behind the actual switch on the dash that turns your lights on, i believe it is a purple wire just use a test light and probe the conector, if you get the right one it will also work with the dimming feature. As for the best match for gauges i like the isspro gauges i have done 2 sets so far one in my truck and one on my fathers and they are a very close match. As for the backlighting all 2008 superduty's light up the same green as i have a harley davidson my father has a lariat and my uncle has a king ranch. Hope that helps
