Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Powerstroke Interior Discussion
Old 09-16-2008, 11:54 AM
Still Strokin Still Strokin is offline
How Do I Remove The Wood Trim ?
Hey I think I can do the dash but how do I get the wood trim pieces to pop off the doors? I want to get rid of it and put the plastic pieces off of an FX4 back in their places. I hate woodtrim. Where would be a good place to buy the factory dash trim piece and the four pieces for the doors?
Old 09-16-2008, 12:04 PM
TwinTurboStroker TwinTurboStroker is offline
Truckless for the moment
The doors are easy, they just pop out, just gotta use a little force, but not too much......
The dash I think is the hardest, your going to have to remove the small ask tray and AUX port to get to the screws behind them before you start pullin on the dash.....
As for where you can get replacement pieces, I not too sure, you can try some of our vendors, I ended up painting mine. I hate wood grain, but I have always like the wood on the Lincoln Blackwood, so thats what I did
Old 09-16-2008, 12:06 PM
DunesRunner08 DunesRunner08 is offline
you can go to the dealership or you can do what I am going to do.... scuff them and paint them.... Duplicolor sells a dash kit specifically for this... you sand the parts and then wipe them off with alcohol and the spray them, let them dry, and clear coat it.... otherwise you can do an online search for overlays
Old 09-18-2008, 10:45 AM
Are the window switches mounted in the door panel itself or are they attached to the wood trim panel that I am removing?
Old 09-18-2008, 12:07 PM
jrod80 jrod80 is offline
I believe the are attached to the wood trim panel.
Old 09-18-2008, 12:27 PM
There are "clipped" into the panels you are removing, same with the dash
Old 09-18-2008, 12:32 PM
Mike Hickman Mike Hickman is online now
Exclamation
I have this same problem I HATE the wood trim in my Lariat watch this thread ..
Old 09-18-2008, 01:42 PM
I agree. I want to swap mine out for the black Harley trim. The FX4 trim won't work since I have the dual climate control so the dash piece is different.
Old 09-18-2008, 01:51 PM
I got the dual climate control too. FX4 wont work? F%$k me. What can I buy that will work just the harley trim?
Old 09-18-2008, 02:11 PM
fsas fsas is offline
+ 1 for hating the woodtrim! Definitely wanna see where this thread goes! All you guys who painted yours...any pics?
