Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Powerstroke Interior Discussion
  #21 (permalink)
Old 08-09-2008, 07:39 PM
grumpygregg grumpygregg is offline
just finished hooking up some backup( idot highbeam reminder) lights under the back bumper. I used the upfitter switch and the pass through wires. If you are tring to find the other ends of the firewall pass through wires , the ones on the drivers side under the hood they are mixed in with the pto wires just below the upfitter blunt wires. They are easy to tell which ones they are because they are they heavier gauge wires in the bundle for the pto and mine had a label around them with a wire color code and what they are. This is the first ford I have seen with tags on wires that say what each wire does. even the extra brake light wire under the truck at the back has a label. All the labels made the wiring easy
