Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Powerstroke Interior Discussion
  #21 (permalink)
Old 04-16-2008, 12:47 PM
vshortt vshortt is offline
Originally Posted by rdkl View Post
Hahah. There was a guy like you on a Toyota forum I was on back in the day. We called him Mr SuperPicky
All in fun of course. It is still a bummer.
Ha! Yeah. That's me. This particular instance really isn't bothering me as much as I'm letting on but there is definitely truth to the fact that my name is essentially synonymous with "particular". IE.....anal (freakin') retentive!
  #22 (permalink)
Old 04-16-2008, 08:56 PM
ardi villiard ardi villiard is offline
vshortt,
I think I have all the same stuff as you (heated seats and mirrors w/ DATC) and I played with it on the way home. I think if you want to change the temp for the entire cab, you hit the Dual button (until the Ext temp shows on the pass side), and then hit the Auto button on the left side by your RED/BLUE buttons. i think that that makes it work the way that you want. Then if you want the pass side at a different temp still in Auto, just hit the dual button again. If you ever want the manual control, hit the OFF under the Auto and you have 2 sides again. Hope that helps.
  #23 (permalink)
Old 04-17-2008, 06:33 AM
Originally Posted by ardi villiard View Post
vshortt,
I don't have a dual button. Hence the reason I started this thread. I really appreciate your looking into it, however.
  #24 (permalink)
Old 04-17-2008, 06:46 AM
Sorry about that vshortt, I confused rdkl's pic with yours. That sure is a bummer.
  #25 (permalink)
Old 04-24-2008, 01:12 PM
Tritonbmc Tritonbmc is offline
Turn the system off, then when you turn it back on, the driver's side control works for both sides. If you have a passenger and they hit their side to change temp, then the system reverts to dual.
  #26 (permalink)
Old 04-29-2008, 10:16 AM
You're kidding me! My truck is in for service right now but when I get it back I'll sure give it a shot. Thanks for the response. I'm sure there are others in my position that have the same issue.
  #27 (permalink)
Old 04-29-2008, 06:17 PM
If it is only showing the temp for the left side, then the dual function is off.
  #28 (permalink)
Old 05-01-2008, 09:59 AM
THAT'S IT!!!!!! Thanks, man. It figures the fix was right under my nose. I appreciate your help in this.
  #29 (permalink)
Old 05-01-2008, 10:04 AM
Barchetta Barchetta is offline
Dirty South Stroker
Send a message via AIM to Barchetta
I am glad you got that squared away. That would have been annoying if you had to deal with separate controls for the life of the truck.
  #30 (permalink)
Old 05-01-2008, 10:06 AM
You can frickin' say that again.
