Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Powerstroke Interior Discussion
Old 04-11-2008, 07:44 AM
nassa cabral nassa cabral is offline
steering wheel Radio controls
Does anybody no the part number or where i can get that little piece that goes into the steering wheel to control the radio my arms get tired from reaching over to change the stations. Also is it easy to install. I already removed the cap thats there and its empty but no wiring, I have 2008 350 XLT model
Old 04-12-2008, 12:14 AM
BigIslandBoy BigIslandBoy is offline
I'm interested in this as well. I have the same same truck. I thought about asking the dealer but haven't had time. I thought I read somewhere that the steering wheel controls are for the audiophile or nav system Maybe someone can verify this for us?
Old 04-14-2008, 06:18 PM
A8050266 A8050266 is offline
Send a message via AIM to A8050266 Send a message via MSN to A8050266 Send a message via Yahoo to A8050266
Item Part Number Description
1 9E740 Steering wheel controls (this is the actual switches you see)
2 — Steering wheel controls electrical connector (part of 3600) (this is the internal connector)
Removal and Installation
NOTE: It is not necessary to remove the driver air bag module during this procedure.
NOTE: When removing the steering wheel controls, disengage the RH side of the controls first.
Using an appropriate tool, pry the steering wheel controls out of the steering wheel.
NOTE: Do not allow the electrical connector to fall back into the steering wheel.
Remove the steering wheel controls.
Disconnect the electrical connector.
To install, reverse the removal procedure.
Old 04-14-2008, 08:55 PM
Wow! Sounds too easy. So the wiring already exists in the steering column and is hooked up to the head unit? I'm gonna have to order the parts and try it. Thanks for the info.
Does anyone know where to get Ford parts cheap? There is on ony one dealer on my island and they are not cheap. Thanks in advance
Old 10-29-2009, 09:14 PM
barry1me barry1me is offline
anyone done this mod? how much does it cost
Old 10-30-2009, 03:58 PM
SPL2K SPL2K is offline
You also need the entire harness that goes into the steering column. Its not as easy as just buying and plugging in the switch.
Old 11-04-2009, 07:51 AM
Slick02 Slick02 is offline
That particular harness does NOT come in all trucks, so the switches won't do you any good without it, so buck up and by an aftermarket unit with a remote if you want laziness..
Old 11-04-2009, 08:33 AM
Cumminspower11 Cumminspower11 is online now
More than likely the XLT's do NOT have the correct harness already inside them. Get the facts striaght before you start tearing it apart... You could run into some problems......
