A/C COLD ON DRIVER SIDE HOT ON PASS SIDE - Ford Powerstroke Diesel Forum
6.4 Powerstroke Interior Discussion
post #1 of 6 Old 06-23-2013, 12:50 PM Thread Starter
just like my title says, I have a 2008 ford f250 6.4 diesel 120k miles
it is a lariat so it has the digital dual climate control, and when I turn on the a/c it is cold on driver side 2 vents, and hot on the passenger side 2 vents, any ideas ? on where to start looking or what to fix?
thanks in adavance
burnin red is offline
post #2 of 6 Old 06-24-2013, 03:04 AM
superBADduty's Avatar
Quoted: 17 Post(s)
Garage
The blend door isn't working properly.
2007 F250 KR CCSB 4x4 ARP's, PMM's EGR delete, PMM's coolant filter, SCT Sf3, GearHead's SRL & SRLXX, Rancho 7000's, IDP FICM tuning, blue spring, Wicked Wheel 2, No Limit Fab. CAI., 2008 rear differential cover.
2006 GMC Savanna 3500 6.6 LBZ Duramax work van
2008 F250 KR CCSB 4x4 quad buckets minimax "SOLD"
superBADduty is offline
post #3 of 6 Old 06-27-2013, 12:48 AM
h1gg1n5's Avatar
Do a search and I think this is a problem that you can fix yourself. I have read a few posts about fixing the blender issue but it does not sound like a fun fix.
2008 F450 CCLB KING RANCH
H&S Mini Maxx w/ Gearhead Tunes | DPF & EGR Removed | Downpipe | CAC Pipe | CCV Mod | Injen CAI |Dieselsite Coolant Filter & Boots| Mishimoto Rad | BFC Headlights
h1gg1n5 is offline
post #4 of 6 Old 07-10-2013, 07:38 AM
johnnyroastbeef's Avatar
I have an '09 Lariat and have the same dual climate control issue you have. If you push the "DUAL" button, (the one that allows the passenger to adjust their sides heat/AC temp,) it will blow cold on that side. it's not a complete fix-as it would be nice to have the AC function like it should- but it's a short term solution. hope that helps.
NEW TRUCK!!: 2009 F350 Lariat CC Shortbed, 2.5" leveling kit, 35x12.5 R20 Toyo Mud Terrains,
-STOLEN 8/26/10!!!
2006 F350 CC shortbed, 2.5" leveling kit, 295/65/R20 Nitto Trail Grappler M/T's-STOLEN 8/26/10!!!
johnnyroastbeef is offline
post #5 of 6 Old 07-10-2013, 08:36 AM
I have a 2008 that is still under warranty. Had same issue. Brought it in and both blender door actuators were bad. It was replaced under warranty, so I can't help you with what the cost might had been.
lilsacbd is offline
post #6 of 6 Old 07-10-2013, 08:38 AM
did you buy an extended warranty? man it would be nice to have that fixed under warranty.
-STOLEN 8/26/10!!!
