Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Powerstroke Interior Discussion
  #11 (permalink)
Old 10-14-2008, 10:12 PM
valetcruiser valetcruiser is offline
it's just a heat supp. for the cab. when you get the option it also adds a heavy duty alternator. i have it on mine and i have not been impressed with it. i guess i need to take it in and get it checked out. maybe it's not working right. they do have block heaters too.
  #12 (permalink)
Old 10-15-2008, 08:55 AM
jbiersba jbiersba is offline
Ditto.
I have this option and I still don't really notice any heat until things get warmed up (engine wise). I believe I read somewhere that it was supposed to increase the cold air temp by ~ 30 degrees. So, if it were 30 degrees outside when you start the truck, the supplemental electric heater should have you pumping out 60 degree air from your vents almost immediately. I have not experienced this.
Granted this is my first diesel, so maybe i'm getting a whole lot more heat quicker than the rest of you guys.
Just to confirm what has already been stated, this unit is not intended to heat up the engine block any quicker, it's just designed to provide warmer air to the cab prior to the engine warming up .
  #13 (permalink)
Old 10-17-2008, 06:10 PM
gleesonkd gleesonkd is offline
Originally Posted by jbiersba View Post
Ditto.
I have it and it works great..... well i'm snowmobiling and its cold with ice snow on the window, i fire up the truck turn the heat up to the highest setting and turn the fan on to the medium setting. and with doing this the truck is warm in about 2 -3 minutes that would be at -5 to -10 outside temp.
  #14 (permalink)
Old 10-17-2008, 08:45 PM
Hamiltonbuilt Hamiltonbuilt is offline
I don't have this and I start my truck and drive for about 10 min. without the heat on and then I can turn the heater on to worm up. At about freezing temps. I would love to add this if I could. anyone, I have an '08 with dual alt.
  #15 (permalink)
Old 11-25-2008, 07:09 PM
So..... I'm going to try this again.
  #16 (permalink)
Old 11-26-2008, 07:28 AM
roondog roondog is offline
ive got one and its not that great.
  #17 (permalink)
Old 11-26-2008, 12:17 PM
powerstroker67 powerstroker67 is offline
Originally Posted by FordCowboy View Post
I'm just curious now, so does this extra electric heater only provide heat in the cab while the truck is cold, or does it aid in heating the engine up as well like a block heater? Do the 08's have block heaters? I would assume they do. Just wondering
The supplement heater just heats the air going into the cab, it doesn't work like a block heater. The block heater is an option in most states, and you had to order the option. There are 3 or 4 states that the block heater comes standard because of extremely cold temps. Cab heater was only an option.
  #18 (permalink)
Old 11-27-2008, 05:48 PM
skipnay skipnay is offline
My turbo charger gauge goes up alittle bit and I start getting heat while the water temperature hasn't moved yet. That's how I know it's working. On a gas motor and guessing deisel motors also you won't get heat until water temperature is up!!!
  #19 (permalink)
Old 11-27-2008, 07:51 PM
STEVONATOR STEVONATOR is offline
I love my bun warmers!
  #20 (permalink)
Old 01-07-2009, 06:44 AM
DavidPhillips DavidPhillips is offline
So has anyone added it yet? How about some installation pictures.
