Need help and info on switching rear bench to captain chairs - Ford Powerstroke Diesel Forum
6.4 Powerstroke Interior Discussion
post #1 of 6 Old 04-19-2013, 03:01 PM Thread Starter
h1gg1n5's Avatar
Question Need help and info on switching rear bench to captain chairs
I'm planning to go ahead with my swap and if anyone has done the swap from rear bench to rear powered captain chairs with center console could you let me know if there is any extra ford parts I need to order to do the swap or wiring to hook up? From the little info I have found on here they seem to just bolt right in but the wiring may be a different story.
I found these pic's of rear captains chairs and they look like different mounting then the front and no power either. If anyone could fill me in on how this might mount or work that would be a big help.
Also on the console it seems there is an extra space filler below the front cup holders that's an extra piece as well. Am I correct?
Thanks for any info...
ID:	99306   Click image for larger version
2008 F450 CCLB KING RANCH
H&S Mini Maxx w/ Gearhead Tunes | DPF & EGR Removed | Downpipe | CAC Pipe | CCV Mod | Injen CAI |Dieselsite Coolant Filter & Boots| Mishimoto Rad | BFC Headlights
h1gg1n5 is offline
post #2 of 6 Old 04-20-2013, 04:14 AM
stinkbug's Avatar
Interesting... Subscribed!
Sent from AutoGuide.com App
stinkbug is offline
post #3 of 6 Old 04-22-2013, 05:18 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Those look different than mine. PM me your number and I'll text you a bunch of pictures tonight when I get off work. I didn't do the swap, but I have power buckets all the way around.
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #4 of 6 Old 05-10-2013, 10:13 PM
I have a King Ranch with these.
The seats and console mount to a metal "tray" that runs full width of the cab.
The "tray" then mounts to the cab, presumably in the same holes.
Mine are NOT power in the rear.
The console appears to be the same, in that it has provisions for the power source inside, etc.
There is a plastic trim piece that is not on the front console, in the lower front.
LMK if you need more detail.....
S1nned is offline
post #5 of 6 Old 07-21-2013, 02:40 PM
wants to go 2wd to 4wd
Send a message via AIM to SniperFolf
More Info? I was just looking into this..
02 7.3, Autometers, TW,4"TB duals, Diy intake..
Originally Posted by Zaairman View Post
LOL... BTS only builds one type of transmission. And that's heavy F'n duty.
Originally Posted by Jake View Post
They call it a threesome when you have sex with 2 other people, a two some when its with one other. Now i understand why they call me handsome.
SniperFolf is offline
post #6 of 6 Old 08-25-2013, 10:45 AM
boostin's Avatar
I also did this swap back in 08,their are some differences but its minimal
2008 king ranch,4x4,quad captains,loaded,manual hubs,manual transfer case(hard to get),8"fabtech 4 link,20in mkw,37 nitto grapplers,mbrp duals
boostin is offline
