Keyed 12volt source - Ford Powerstroke Diesel Forum
6.4 Powerstroke Interior Discussion
post #1 of 6 Old 04-16-2013, 09:02 PM Thread Starter
Keyed 12volt source
Ha all I have a 08 f350 looking for 12volt wire on ds of truck need to hook up red wire for plow I can only find the upfit wires but don't want to use these.so if anybody can shed light would greatly help!!!!
Tow21 is offline
post #2 of 6 Old 04-16-2013, 10:29 PM
dieselforfun's Avatar
Quoted: 2 Post(s)
Violet wire in wire harness under dash drivers side test it first
dieselforfun is offline
post #3 of 6 Old 04-17-2013, 09:19 AM Thread Starter
Ok I will I did test all the wires that that wire tied under the ds dash but got no power with key on or off ill look again thanks
Tow21 is offline
post #4 of 6 Old 04-18-2013, 09:30 AM
The purple wire should be there and is a fused 10amp supply. Its blunt cut and I think its in the bundle with the pass-thru and SEIC wires.
Fuse is #44 in the passenger side fuse box.
Turgin is offline
post #5 of 6 Old 06-02-2013, 10:06 AM
NVHunter83's Avatar
Are those the only key on power sources under the dash? The purple wire is already occupied by my Mini Maxx. I want to install a lock which is powered on with the key on, and dead with it off.
2008 Ford F-350
6.4L Power Stroke
Crew Cab Long Bed
Buck Stop Bumper w/
WARN 9500 lbs. Winch
H&S Mini Maxx w/ homemade mount
5" Flo-Pro DPB exhaust w/ muffler
Bilstein 5100s Shocks
AFe Stage II Magnum Force Intake
NVHunter83 is offline
post #6 of 6 Old 07-01-2013, 09:41 PM
you could t-tap onto the ignition wire in the harness on the steering column you will be looking for a white/orange violet/green or you could also use the brown/yellow remember to always test with a volt meter or a power probe do not use a test light as there are some data wires in that harness and it could cause damage to the bcm i work for a company in my town and do this everyday. also these wires are a very small guage so make sure you t-tap it good and then use a relay and use the above wires as a trigger and be sure to fuse your constant if you cant find the wires let me know and i can post some pictures of my remote start in my truck to give you an idea of what to look for hope this helps
bjohn118 is offline
