How do I remove the blank dash plate - Ford Powerstroke Diesel Forum
6.4 Powerstroke Interior Discussion
post #1 of 9 Old 02-25-2013, 05:10 PM Thread Starter
I want to mount my mini maxx on the blank black plate where the 4x4 knob is usually at. Does anyone know how to get it out? I thought about trying to just pry it out but I have a knack for breaking little plastic tabs off things. Thanks for the help
aaron250r is offline
post #2 of 9 Old 02-25-2013, 06:30 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 13 Post(s)
Feedback Score: 12 reviews
Yeah just pry from the top with a plastic tool or just be careful with a pocket knife (how I pop them out) or you can scuff up the dash if not done smoothly
Sent from AutoGuide.com App
2017 f250 platinum
Bone stock until warranty expires!
mts678 is offline
post #3 of 9 Old 02-25-2013, 06:38 PM Thread Starter
Alright thanks for the help I wanted to make sure before I just started prying on it.
post #4 of 9 Old 02-25-2013, 06:40 PM
44magnum's Avatar
Quoted: 2 Post(s)
Or you can just pop off the whole dash panel, like you would if you were removing the radio then you can push it out from the back so you'll be less likely to break off any tabs or scratch the dash.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #5 of 9 Old 02-25-2013, 07:08 PM
mts678's Avatar
Quoted: 13 Post(s)
That's true. Especially if ur prone to breaking plastic tabs I'd do it as magnum suggested, more safe
Edit: I forgot, you still have to pop out the two lower inserts to take the bolts out so you can remove that dash piece. Just pry easy with a plastic tool
2017 f250 platinum
mts678 is offline
post #6 of 9 Old 02-25-2013, 07:24 PM Thread Starter
How hard is it to get the whole dash panel off? I haven't taken any of the interior apart on a truck since my '75 F250 high boy.
post #7 of 9 Old 02-25-2013, 08:03 PM
mts678's Avatar
Quoted: 13 Post(s)
Pop off the two lower plates:
Left side is the cig lighter
Right side is the audio headphone jack input
Pop those off and remove the two 5/16's bolts then you just pull the dash section out, it's held in by plastic clips that'll just pop out easily when you pull on it
2017 f250 platinum
mts678 is offline
post #8 of 9 Old 02-25-2013, 09:35 PM Thread Starter
Ok thanks all I appreciate the help.
post #9 of 9 Old 02-25-2013, 09:53 PM
mts678's Avatar
Quoted: 13 Post(s)
Sure man
2017 f250 platinum
mts678 is offline
