Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Powerstroke Interior Discussion
Old 12-19-2007, 04:47 PM
Goolsbymd Goolsbymd is offline
Project Abused
Installing Gauges picture guide
First off I went with the Tranny temp, Pyro, and boost gauges from Isspro and a 3 gauge pillar, you can get this kit from Diesel Manor. The pillar comes in black so, if you want to match the color you will have to paint it yourself, but don't worry Diesel manor also supplies the factory paint to your cabin so it all matches. Heres the kit and the painting process the rest of the install will happen on Sunday.
I know the intruction says 07 6.0 but they said it will all work on the 6.4s
Was to cold to dry outside so made a little home made spray booth, just tapped up a trash bag on top of the stove and turned the fans on and sucked the fumes out.
Old 12-19-2007, 08:50 PM
Spatel23 Spatel23 is offline
Nice, cant wait to see some finished pics.
good luck with the install
Old 12-20-2007, 06:18 PM
onebadf150 onebadf150 is offline
wow looks great !
Old 12-20-2007, 06:21 PM
rankroddin250 rankroddin250 is offline
I wonder why they dont all come in grey standard? like 99% of vehicles out there come from the factory with grey interior!
Old 12-24-2007, 02:20 PM
Project Abused
Ok we didn't finish today cause my buddy who was helpin got in trouble with the wife, long story short this SMOKIN bombshell (brown hair, big jugs, nice legs, walked by us in a turtle neck sweater, a black leather mini skirt, and knee high boots) well we turned and looked, and started talking about her, well his wife walked up behind us and busted us and almost killed him. But this is what we got done:
took off the factory pillar , drilled the holes for the wireing, hooked up all the wire (plug and play pretty much) put the pillar back on with the gauge pillar bolted em together, ran the cables down the side. We tried first to put the gauge light power cord (red) to the fuse box on the passenger side. We tied it into the cluster fuse, thinkin when the cluster is on the headlights are on so when its off the gauge lights will turn off; didn't work always got power even when truck off and doors open. Same thing when we tapped it into the headlight fuses. Then i had the idea, I paid for these up fitter switches lets use em! So we spliced them into the Aux One switch. (yellow wire left side of the steering collum, will be labeled with a piece of tape) now the only thing is I have to manually flip the switch when i want the gauge lights on, which for me works out better cause I like to drive completely blacked out in the cabin at night. Heres a little picture summary. Ill tap everything in to its componets later this week.
Factory pillar removed, along with the weather stripping.
The red cable runs up from under the weather stripping and is spliced into the yellow wire for up fitter switch #1:
Up fitter has the power and the gauges are luminated:
im thinking about removing the bulb covers to make them shine brighter.
Old 12-24-2007, 02:22 PM
Project Abused
Im gonna have to get more orange wire for the tranny temp as i don't have enough, also ill be drilling a bigger hole in the firewall to open it up so I can fit all the cables through and ill drill into the U-tube connecting the turbos for the boost gauge, and pre-turbo for the pryo.
Old 12-24-2007, 02:59 PM
tucker tucker is offline
All those pics and none of the hot blonde? JK
Nice job!
Old 12-24-2007, 03:06 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Looks good
Old 12-24-2007, 03:17 PM
Project Abused
Nice job!
I live next to her, I didn't think it would be a good idea to take a picture of her with his wife there
Old 12-24-2007, 04:11 PM
Strőkër~X Strőkër~X is offline
Send a message via MSN to Strőkër~X
LMAO-(smart guy), install looks sweet, i like your gauge style.
