2010 king ranch interior trim codes - Ford Powerstroke Diesel Forum
Old 02-03-2013, 11:16 AM
I am in the process of mounting a programmer on a dash pod in my king ranch, but want to color match the pod to the trim. I'm having a heck of a time trying to find out exactly what the ford trim color is, even the people at the dealership give me a blank look. maybe someone here has experience with this.
I have a listing of motorcraft interior trim codes for the 2009 models, but can't seem to find one for 2010.
The door tag shows trim codes SC which according to the 2009 codes would be Medium stone & Camel. Then under the dash is a Tag that shows HS charcoal/camel. The actual trim pieces are a metalic silvery grey color which doesn't match medium stone paint chips at the paint store, If I can nail down exactly what the color is.... then it shouldn't be a problem from there.
2010 king ranch interior trim codes-img_0335-small-.jpg   2010 king ranch interior trim codes-img_0340-small-.jpg   2010 king ranch interior trim codes-img_0337-small-.jpg   2010 king ranch interior trim codes-img_0339-small-.jpg
Old 02-03-2013, 04:54 PM
I was just going to post up a King Ranch interior color question, then I saw your thread.
My 2008 (Lariat) has the medium stone (I think thats what its called) interior.
A friends 2008 KR has an interior color thats more 'yellowish'. Is that a tan color? What interior colors were available with the King Ranch, or were they all the same? I prefer the medium stone vs the tan color...
Old 02-03-2013, 05:47 PM
I believe the yelowish/tan color is called Camel. From what I can tell there were 3 base interior colors available in the King Ranch. i) Camel, ii) Medium Stone & iii) Ebony combined with the Chaparral leather. Along with these base colors I think there were 3 two tone accent colors i) Pueblo gold Metalic, ii) Sterling Grey metalic & iii) Tuxedo Black metalic. How did Ford combined these colors..... I don't know, as I'm still confused on how to interpret the 2010 specs that I have, & none of this seems to jive with the trim codes I thought I had found on my truck.
http://assets.forddirect.fordvehicle...E8E84C10E8.pdf
Old 02-05-2013, 03:53 PM
Sorry, the above is not quite correct.... at least for the 2010 model year, the 3 base interior colors, Camel, Medium Stone, & Ebony were the interior colors available for all the superduty models. The King Ranch was only available in Camel. Now that being said.... I did read on one of the forums were someone had special ordered a 2010 King Ranch in Ebony.
Also found out the Trim code SC does NOT denote the 2 interior colors as I was lead to believe. The first letter/digit in all Ford trim codes denotes the Trim Style & the second one denotes interior color. In this particular case the S denotes the unique King Ranch leather used.
page 49 on this document shows it
http://hillerford.com/resource_libra...50f350f450.pdf
Still haven't figured out the color of the dash side pieces or if the sticker under the dash means anything or not
Old 02-05-2013, 06:08 PM
So, thats good to know - I prefer the Medium Stone over the Camel though. The Camel is too 'yellow' for my liking...
Are you referring to the silver metalllic type of side pieces?
If so, here is a link to a thread that shows two different H&S mounts - they make a painted one to match that silver piece (which I just found out about) and a black one. I posted a link to a thread about painting to match to the silver side pieces in that thread...
What programmer are you going to use? I have seen a few different tuners mounted into the painted one, although some I beleive might just be gauges - Ive seen pics of the Edge, MSD Dashhawk, and Spartan Dashdaq all made to work with tha one..
H&S mounting
Old 02-06-2013, 02:33 PM
Thanks for the link, interesting the fellow was able to color match using two different colors. I have the H&S mini max & the 31303 H&S/bully dog gauge pod.
I was reluctant to order the painted pod sight unseen incase it didn't match. Also if I recall the painted mount was a lot more expensive last fall when I was ordering parts, but maybe I'm thinking of something else. Yes, its the dash side trim pieces I'm trying to color match. If I knew it was going to be this difficult to find the correct trim color......
Old 02-06-2013, 08:07 PM
I am going to look for some paint in the next few days then paint mine...
I will let you know how it goes - if you try paining first let me know how it went...
Old 02-07-2013, 10:21 AM
Here is an interesting Catalog from Sherwin Williams paint.
http://www.sherwin-automotive.com/Re...ColorBook.ashx
It is their paint catalog for 2010 vehicles. On pages 31 to 56 it shows the color compatibility for all the 2010 ford models. Basically take your outside paint code( in my case "UK" royal red) & your model ie: Super duty F series truck, & it shows all the different colors that may have been used in various locations on the particular vehicle. Under the interior header it shows 2 different grays that may have been used in the interior.
On page 28&29 it shows all the interior paint chips . 6T7A "greystone" does Not match my side panels. 7NEC "Dark foundry Metalic" apperars to be a perfect match.
Did another search using this color name & # it comes up available thru NAPA's Martin Senour paints which I think may be "branded" line of Sherwin Williams" paints.
Unique Formula#4009330 Tec/one Interior single stage "Dark Foundry Metalic" 7NEC.
Also SEM paints "color coat" line shows a "Dark Foundry Metalic" formula #5915 as available.
I need to limp into town to varify this info & see if its actually available or not. Some of the auto supply stores have the ability to mix certain formulas into aerosol cans so for the amount of painting I need to do that would be the way to go rather than shooting it from a spray gun. I'm not gettin around to well these days after taken a bad fall, so it might be a while before I get to this, but maybe this info will help you decide what you need for your truck.
Old 02-07-2013, 04:59 PM
That's an awesome find! I'll use that catalog to paint my new mini maxx gauge pod.
Old 02-07-2013, 05:57 PM
Nice find!
I was not able to find Duplicolor Textured Metallic Charcoal MX101...
I ended up with Duplicolor Textured Metallic Graphite - it seems a bit darker!
I also found this link and picked up a can of this stuff - Krylon textured plastic paint.
Dash Paint - PowerStrokeNation : Ford Powerstroke Diesel Forum
I also got a can of Duplicolor Perfect Match Charcoal Metallic - its just paint, not textured.
My gut feeling is I will use either the Duplicolor Textured or the Krylon textured, with a dusting of the Charcoal Metallic
I have a black piece of plastic similarly textured to the pod - I will try some paint samples...
I wonder if that Dark Foundry Metallic is textured? If not, it might be the perfect candidate to spray over either of the two textured paints to not only match the dash color, but to give the same rough textured look like the factory pieces...
