How to change bulb in dome light? - Ford Powerstroke Diesel Forum
Old 02-02-2013, 06:50 PM
I think the center bulb on my front dome light is burned out. The two side lights work with the switches and the rear dome light is working. How do you take that light off - I didnt see any screws, and I am not great with the clips that are used everywhere nowadays. I guess its ok if you know what direction to push, but these big hands and old eyes are not condusive to that stuff...
Old 02-02-2013, 07:11 PM
You gotta yank her straight down! Best of luck pulling the bezel down. Some break and some don't.
Old 02-03-2013, 07:49 AM
Flat head screw driver and lots of patience and pulling slightly... It's not terribly hard.
Sent from AutoGuide.com App
Old 02-28-2013, 01:59 PM
When doing it , upgrade and go with the LED bulbs, you will not regret it , i did mine and its awsome.
Old 02-28-2013, 06:47 PM
6 of these bulbs = AWESOME
2 x White 1 72" 42mm 12 SMD LED Dome Light Bulbs Super Bright C50 | eBay
Old 03-01-2013, 02:16 AM
be really careful, that part is around 300 from the stealer and $180 from Tasca. i broke mine when my sunroof switch housing broke and i was attempting to remove the bezel.
good luck,
Old 03-01-2013, 03:44 AM
Stick a flathead in the slot and twist it vice prying... it will pop off.
