help changing map/dome light - Ford Powerstroke Diesel Forum
Old 06-11-2012, 02:42 AM
Have a light out up by my rear view mirror. Does that plastic ring snap straight up onto the roof? Don't want to break it pulling it down. I was trying to pull it straight down but it seemed soo stiff
Old 06-11-2012, 10:09 AM
Error 404: Page Not Found
I replaced my cab light bulbs about 3 weeks ago. I pulled mine off by hand but if you aren't comfortable with that, just use a butter knife or fine tipped flat head and the clear plastic will pop right off. Then pull the old bulb out and pop the new one in.
Old 06-11-2012, 10:33 AM
For the map light?
Old 06-11-2012, 10:56 AM
Like this:
Unless your lights dont look like that, then I have no idea what you mean.
Old 06-11-2012, 11:48 AM
those are the rears. I want to replace the fronts and there is a plastic ring around the two lights. I just didn't know if that ring snaps in? It feels like the thing is going to snap in two with how much tq I'm putting on it
Old 06-11-2012, 03:00 PM
Sorry then, I have a crew cab with two of those lights and nothing else. So I don't know what your taking about. Hope someone else can help.
Sent from my ADR6400L using AutoGuide.Com Free App
Old 07-10-2012, 12:36 PM
Mine has a sunroof for it has a different style map light up front. I assume the OP does has the same. I would also like to know how this comes off. I haven't tried mine yet as my lights still work but would like to swap them for led lights.
Old 07-10-2012, 02:56 PM
I do have a sunroof. Just had the dealership change it while it was in the shop for something else. I didn't want to break it
Old 07-12-2012, 01:50 PM
Dont Mess With Texas!
Yes, i have a sunroof and it has the same one you are talking about with the switch in the center...just take a flat head screw driver in their and pry it straight down. it will pop off. I was the same why nervous about breaking it but it worked just fine.
Old 10-11-2012, 04:52 PM
i did mine today and broke it. looking for a new piece now. did a temp job with double stick tape to get it back on for now
