Center Console
I have a 2010 F-350 Lariat. There are two things I dislike about the interior: 1 being the wood grain panels; the other being the center console. Typically, a center console extends all the way to the dash but, mine stops at the cupholders. I like the center console in the 2011 models. Would anyone know if that console would be a direct fit in to the 2010? The dash doesn't seem to have changed. Also, with being overseas, I'm limited on resources; I can't find the black replacement panels for the wood grain. Does anyone know where to find them?
Thanks! |
Yes it seems to be a direct fit, it hasnt been tried yet because the parts list goes upwards of $1700. I dont know about the panels although i do have them in my truck
$1700? Wow! I'll have to see if it's worth it. Maybe I can find something else. Hell, for $1700, I could have a custom console made. Thanks mayne!
ya it is a lot, im still waiting to find some that are salvaged or on ebay...
As stated, the 2011+ console will fit in the 200-2010 trucks. It is comprised of 32 separate part numbers and is just shy of $2000. $1968.24 with "bro pricing." As far as changing the woodgrain, I've seen kits available in many different colors and materials available online. Remin, B&I, and Sherwood are some of te manufacturers I've seen. Don't know much about them though.
Here is an old thread I started., ome of my photobucket links dont work but some still do, check it out. I had the interior panels "dipped" in a process called hydrographics. It is the same process used to camo a gun stock and is affordable if you shop around. This is pretty much the best thing I have done to my truck... I dont see the lift when I am driving, but I see the dash... Oh, do not use the sticker kits, you will not be happy. There are molded kits for our trucks, but not with the Lariat climate control, they only fit standard a/c switches.
Dash and switch panels
That looks awesome! Hope there is somewhere around here I can get it done.
