My glovebox leaks? - Ford Powerstroke Diesel Forum
Old 09-26-2011, 05:05 PM
My glovebox leaks?
Yesterday had a heavy rain(don't know exactly, as I wasn't home when it rained but the truck was, and it was parked) opened the passenger door later and saw a little water on the floormat. Thought, hum, wonder where that came from. Then opened the glovebox, it it was flooded! WTH?
I've never had a car or truck leak INTO the glovebox!
Where to start and what to fix/check?
Old 09-27-2011, 05:49 PM
Anyone with an idea?
Old 09-27-2011, 06:33 PM
Well have you had the windshield replaced/ and or any shady mods that require drilling through the fire wall?
Old 09-27-2011, 06:41 PM
The Tamed Racing Driver
Pull the glove box out and look up
Old 09-28-2011, 03:35 AM
Do you have cab lights? If so inspect for a cracked base.I had one that in heavy rains would leak into my dome light.( I have a sunroof) If no cab lights I suspect the windshield is your cause.
Old 09-28-2011, 03:58 AM
Sounds like the air duct for the air conditioning, it comes in right in front of the wind shield and when it leaks, it leaks a lot.
Old 09-29-2011, 05:57 PM
No mods, shady or other.
What might I be looking for or at?
I do have cab lights, and a sunroof. I'll go check for cracks right now. Am I looking for something obvious, or small and easy to miss?
Ok. Why would it be leaking? A clogged drain or something cracked/broken, or something loose and not connected. I have had a variety of issues since FoMoCo took the cab off the r&r the engine.
Old 09-29-2011, 07:18 PM
take the glove box out and run it through a car wash. Or have someone run water from a garden hose over it while you are looking for water leaks.
Old 10-03-2011, 06:42 PM
Tried that. Didn't leak when I washed and rinsed it. Doesn't leak every time it rains. Only every once in a while. Sometimes on the driver side, sometimes into the glovebox. I don't mind too much about the driver side, although would like to stop it before rusts starts, but into the glovebox is a real pain!
Old 10-09-2011, 05:44 PM
Dont Mess With Texas!
if it is happening on both sides i would damn near bet on it being a bad seal on the windshield, have you had the windsheild replaced lately or just bought the truck used maybe the owner had it replaced? good way to tell is if it doesnt had the SUPER DUTY logo on the windsheild top dead center
