LED interior dome light bulbs. - Ford Powerstroke Diesel Forum
Old 08-23-2011, 06:38 AM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
I would like to change all of my interior dome lights to super white LED's. The stock interior lights are just to dim. Has anyone done this and have part numbers for the bulbs I should use? Also experience in LED brands not to use? Final question is will I need resistors or can i just plug the bulbs in and go.
Old 08-23-2011, 09:32 AM
Send a message via AIM to Duffie112
I did mine with recons and there just plug and play. There super bright compared to stock and have a blueish tint. But i like them no complaints which is suprising coming from recon latley. Hope this helps
Old 08-23-2011, 12:08 PM
I am trying to steer clear of recon. I have a few friends that used the recon bulbs and they ended up having the bulbs go bad in less than a year. An LED that isnt used very often should last the life of the truck.
Old 08-23-2011, 12:12 PM
Dont Mess With Texas!
how did you pull the push button lights that are right behind the rear view mirror off? i need to pull the whole assembly off and change a bulb out but i am afraid to do i just pull the whole thing down?
Old 08-23-2011, 12:14 PM
i had recon LED bulbs on my truck for over 2 years and they never went bad...
the bulbs change out pretty easily.. all my vehicles have LED interior dome lights installed... they make a big diff
Old 08-23-2011, 12:26 PM
raul do yall sell those?
Old 08-23-2011, 12:37 PM
yup we do.... just PM me the details on your truck.. if it has the map lights or not and how many dome lights you have..
the kits come with 3 bulbs which is enough for 1 dome light housing
Old 08-23-2011, 12:46 PM
this is what i have raul
i want all the lamps (led) for this one
rear
all both lamps or however many it takes for this one
front
Old 08-23-2011, 12:47 PM
does anyone know how to pull those down so i can replace the lamps? do i just pry them straight down?
Old 08-23-2011, 01:10 PM
It will take two kits for your set up with one bulb left over. Im getting ready to go out and look it over to see how it comes out
