Interior dome lights short circuited - Ford Powerstroke Diesel Forum
Old 07-25-2011, 06:47 PM
Hey everyone,
I was installing flip down dvd player in a 2008 F250 and when trying to figure out the lights for on and door open I short circuited all the dome lights. I took my power probe to the fuse panel on the passenger side and check every one. All of them are good. I took out #9 and #10 and visually inspected, and they are good. When I give power to the positive side, they turn on.
I need some help!
Old 07-26-2011, 02:24 AM
Welcome to the ORG!
I will bump this up so someone who knows may be able to help.
Old 08-04-2011, 04:22 PM
The wiring diagram shows fuse 9 and 25 in the smart junction box in the pass kick panel
did you cut a wire accidentally?
Old 08-04-2011, 08:50 PM
You prob fried the relay when you touched something and shorted it out. Recheck all your fuses and then feel your relays. If any of them looked burnt or discolored or feel warm, that could be your problem. Im not going to go into static checking the relay but if you know anyone that has a DMM and know about electronics, call them. Only so much you can do through a forum.
