Where to buy auxillary switch panel? - Ford Powerstroke Diesel Forum
Old 07-20-2011, 05:56 AM
Anybody know where I can buy the auxillary switch panel for an '09 250. I bought the truck used and it has a change holder where the switches should be. Any help would be appreciated.
Old 07-20-2011, 09:01 AM
Send a message via Yahoo to sredmyer
Here is a set
F250 Trailer Brake Controller Auxilary Switches 09 OEM | eBay
Steve
Old 07-25-2011, 06:41 AM
These are called upfitter switches. They are available through plenty of the performance shops online. Just about any shop that carries lights and air horns etc will also have them in stock.
Old 07-25-2011, 09:21 AM
Served Our Country!
Feedback Score: 3 reviews
Send a message via AIM to HighOn20s Send a message via Yahoo to HighOn20s
I am in the same boat.... I am about to switch my bumpers and run lights and I have the change holder... my question is when you remove the change holder to do the swap is there a harness plug behind it for the switch panel?
Old 07-25-2011, 05:28 PM
Yes and no. The new harness and relay assembly will run along the inside of the dash and connect on the driver's side. I installed mine shortly after buying my truck in October and it is fairly easy to do except for one connection that was up near the firewall. It was hard to get to but not impossible.
This should help you out (2008-10):
https://www.fleet.ford.com/truckbbas/non-html/q157.pdf
Old 08-11-2011, 01:35 AM
Check Ebay , Just seen them , OEM factory part.
Old 08-13-2011, 10:10 PM
Im in the same boat.
Old 09-04-2011, 01:20 PM
i seen them online today for 160ish
call 888 four six nine 7278 ext 8
Old 09-15-2011, 08:28 AM
Send a message via Yahoo to skipnay
After looking at this for about 2 weeks why not just get a flat piece of plastic to fit in there and add the switches you want? Then run the wire? I'm sure the wire isn't where you want it anyway?
Old 09-18-2011, 07:13 PM
Found them on ebay. Just trying to find time ot install them.
