2010 Squeeking noise
my dash is making an annoying skueeky noise while drivng down th road. If you push on any part of the dash on the left of the steering wheel it stops. Anyone had this problem? How do you stop it?
I have the same problem; I have taken it to the dealership twice and still have the squeaking noise. They replaced part of the steering shafting and the grommet on the fire wall. It seems to be coming from the around the steering wheel. When I pull down on the steering wheel it stops, but is also stops when I push in the panel right under the steering wheel. If you find out what causes it before I do let me know. And I will do the same.
I had a vibration sound coming from under the dash on the left side and at times it would stop or not even make noise. Took it to Ford and it was a vacuum issue, they replaced the part under warranty, no issues since
