Upgrade window motors and switches - Ford Powerstroke Diesel Forum
6.4 Powerstroke Interior Discussion
post #1 of 19 Old 02-08-2011, 12:52 PM Thread Starter
smotrs's Avatar
Question Upgrade window motors and switches
I'm looking to modify my power windows so that both fronts windows support Auto, not just for rolling the window down but also to roll the window up.
I'm wondering if anyone has approached this? Would it be just switches or motors and switches? Other then labor which can be a DIY project, I can't see it being too expensive. Just a matter of whether it will work or not.
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT's
Avic-Z2 Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, Six-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares
Ravelco Anti Theft Device
Originally Posted by Rick Santorum
We went into a recession in 2008 because of gasoline prices.
smotrs is offline
post #2 of 19 Old 02-08-2011, 01:52 PM
sredmyer's Avatar
Send a message via Yahoo to sredmyer
I would also like to do this...hope someone has some insight.
sredmyer is offline
post #3 of 19 Old 02-08-2011, 01:57 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Seems to me its the switch as a whole, not the motor. and I have looked into it. BUT, you cannot seperate the single auto switch out of the block of 4. (I have a CC) They are made into one peice. If anyone could do it, i would love to know how. as I have a second window block here waiting to do the conversion. I would love to do all 4.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #4 of 19 Old 02-12-2011, 01:39 AM
NathanScott's Avatar
I have the Viper 5901 and installed the DEI 530T window modules for the front and rear windows. The 530T has one touch up and down which I use all the time. I believe you can install them without an alarm. You will only need one module for the front drivers and passengers windows. If you want to do the back window also, you will need to get another one. I got them from this seller on eBay for about $50...
CarStereoNeeds 530T
They are not hard to install, but you do have to cut into some wires in the driver side kick panel area and run 4 wires into the drivers door which was not easy. There is a wire harness plug connecting the electrical for the door to the body, not a rubber boot like older cars so you will have to get a little creative.
NathanScott is offline
post #5 of 19 Old 02-12-2011, 06:19 PM Thread Starter
smotrs's Avatar
Thanks for that link Nathan, definitely gonna look into that more.
Shaun
Line-X bedliner
smotrs is offline
post #6 of 19 Old 04-01-2011, 06:19 AM
http://www.thehoffmangroup.com/autol...netouchwindows
This is what you need. I had these on my old 2001 F150 bagged truck. works with any remote
stevep1794 is offline
post #7 of 19 Old 04-01-2011, 07:42 AM
You can also use a drivers window control module from a early 90's Thunderbird and Explorer. Gives you both auto up and down on the door its installed in.
Stroked02F350 is offline
post #8 of 19 Old 04-01-2011, 07:51 AM Thread Starter
smotrs's Avatar
Thanks, I'm still looking into things, I'll check this out as well.
Shaun
Line-X bedliner
smotrs is offline
post #9 of 19 Old 02-02-2013, 01:15 PM
WydOpen's Avatar
Send a message via AIM to WydOpen
Bringing this back from the dead after doing a little research...
Lately I've been looking at picking up a used 2010 Lincoln MKS with Ecoboost as a daily driver and came across something interesting while studying the interior. I noticed the Lincoln MKS has all four auto up/down feature and the switches look identical to the Super Duty. Anyone know if the connectors are interchangeable and this is as easy and plug and play???
Lincoln MKS (Ford OEM P/N AA5T-14540-AAW)...
08-10 Crew Cab Super Duty (Ford OEM P/N 8L8Z-14529-AC)...
I also checked with a buddy of mine and his 2010 Shelby GT500 convertible has all four auto up/down buttons.
Hell, even the new 2013 Super Duty Platinum doesn't have all four auto up/down buttons...WTF???
I'd check in to the connector myself, but out to sea right now.
- Rob
2015 Tuxedo Black F250 CCSB Platinum FX4 6.7L PSD
PMF 2.5" Alpha Series | Fuel 22x10 Mavericks | Nitto 325/50-22 Trails | Edge CTS2 | AMP PowerSteps | RetroShop Headlights
WydOpen is offline
post #10 of 19 Old 02-05-2013, 11:24 AM
h1gg1n5's Avatar
They look like they have different plugs in the back:
Lincoln:
2011 LINCOLN MKS MASTER POWER LEFT WINDOW SWITCH BUTTON OEM AA5T-14540-AAW | eBay
Super duty:
08 Focus Master Power Window Switch Left Driver LH 8L8Z 14529 AC | eBay
2008 F450 CCLB KING RANCH
H&S Mini Maxx w/ Gearhead Tunes | DPF & EGR Removed | Downpipe | CAC Pipe | CCV Mod | Injen CAI |Dieselsite Coolant Filter & Boots| Mishimoto Rad | BFC Headlights
h1gg1n5 is offline
