Sub box install? - Ford Powerstroke Diesel Forum
Old 01-30-2011, 07:37 PM
Sub box install?
hey
new to the forum and unsure if this topic has been covered.
i recently purchased a sub box from supercrew sound for behind the backseat of my crewcab(dual 12s).so,what is the best way to install.take out the rear seat?or is the middle seat belt bracket movable?-30 were i am so i was hoping to spend as little time possible outside.thanks
Old 01-31-2011, 02:07 AM
I haven't done my 2010 yet, but I put in a SCS 2X10 box in my 2002 F350 CC and I took the rear seat out to mount the box (and the amps + Eq's). There just wasn't enough room to do the install with the seat in place, IMHO.
Old 02-07-2011, 08:50 AM
x2 for seat removal. If the box fits properly then it'll be tough without doing it
Old 02-10-2011, 07:58 PM
Send a message via AIM to NorCal510PSD Send a message via Yahoo to NorCal510PSD
x3 for seat removal...i think you're going to have cut the panel behind the seat to fit the box properly too...
Old 02-16-2011, 10:01 PM
How about just putting spacers under the seat brackets and have your speakers sit underneath the seat? I got the boes to fit underneat but kinda having trouble finding a good spacer that will allow better clearance for the sub box. Right now im using big washers, sitting up the seat .5 in., but the front part of the back seat bracket still isnt fully fastened? any ideas for a good spacer
08 crew 4x4 f250
Old 02-17-2011, 06:16 AM
I hate seat lifts! I used to put them into the late 90's f150's. Maybe it's the fact that they raise the seat into the visibility area of the back window or just the fact that it looks like there would be a massive increase in the amount of stress put on the bolts, I don't know but they don't seem safe. With so much space behind the seat are you just considering it so you can run deeper subs? If you are insistant then look online for seat lift brackets. They are basically a piece of c channel iron and new bolts. I've seen them as tall as 4" for the older trucks.
Old 02-20-2011, 12:20 PM
I went with the JL Stealth box. Yeah it costs more but I didn't have to cut out or drill my cab up!
Old 02-20-2011, 07:57 PM
Send a message via AIM to Dim Sum
Did you install it yourself?
I ordered a stealthbox, JL XD600/1, and new CXI570s. Also planning to do hushmat on all of the doors / back wall.
When it came down to it, it was either SPL4k or the Stealthbox and I thought I'd rather give up the under seat area than behind the seats.
Old 03-16-2011, 02:02 PM
Old 03-19-2011, 09:28 AM
Send a message via Yahoo to skipnay
Originally Posted by BigKuntry View Post
What he said....
