reverse sensor - Ford Powerstroke Diesel Forum
Old 12-09-2010, 10:51 PM
Send a message via AIM to NorCal510PSD Send a message via Yahoo to NorCal510PSD
reverse sensor
I just got my new truck a few weeks ago. Somtimes I start it and the reverse sensors are working, somtimes the off light is on and they arent working. If i push the button nothing happens. Is there a way to keep them on all time??
Old 12-10-2010, 07:52 AM
it could be the module is going bad. thats what happened on my 06. i bought my truck new, and a few days later the reverse senors started acting up. it was replaced under warranty. since the new one was installed i have not had a problem with them.
Old 12-10-2010, 07:53 AM
Sounds like something's wrong with the button or something, mine are always on unless I push the button off....
Old 12-11-2010, 09:12 AM
well sounds like ill be taking it to the dealer thanks guys!!
Old 12-19-2010, 10:14 AM
I got the same problen, how long was your truck at the dealers for?
Old 12-19-2010, 10:17 AM
only a few hrs. not long at all. its probably one of the best options that i purchased. saved me a few times. well worth getting it repaired.
Old 12-25-2010, 06:40 AM
If you catch it not working you can test the sensors by leaving the truck in reverse, setting the e-brake....double check that! then get out and put your ear by each one of the sensors, each one should be ticking similar to a stun gun, if not it's defective and one bad sensor will cause the system to stop working. I had a rock hit the back side of my outside sensor and the dealer couldn't figure it out. When I told him this was how to fix it he said I was crazy, we bet on it and I now have a spare sensor!
Old 12-25-2010, 07:43 AM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
Ill have to look into this as well. Ever since I hit an elk a few weeks ago mine have been acting up and only work 60% of the time. Im not sure how the back end could have been affected by a front passenger side impact, but wierder things have happened...
