Climate Control - Ford Powerstroke Diesel Forum
6.4 Powerstroke Interior Discussion
post #1 of 18 Old 11-19-2010, 04:44 PM Thread Starter
Climate Control
I have a 2010 F-250 that has recently started blowing hot air on the passenger side and normal air temperature on the driver side. If I have the dual controls turned off and have the cab temp set at 70 it blows fine for a bit and then the passenger side blows what feels like 90 degrees. If I turn it on dual it levels out after I decrease the temperature all the way to 60 and then adjust back up. It stays normal for awhile and then starts heating up again. Any ideas????
2010 Ford F-250 Lariat Crew Cab. Edge Racing Programmer, AFE Exhaust and S&B Intake.
planahd is offline
post #2 of 18 Old 11-28-2010, 08:08 PM
Subscribed - I have an 08 F250 that is doing the same thing.
weekendplayer is offline
post #3 of 18 Old 12-06-2010, 09:19 AM
Its a problem with your blower or blend door actuators. Mine is going in Wednesday for the fix.
2008 Dark Stone F250 CC,4x4 Lariat, Job3, 3.73 gear
Banks CAI
ATS Painted Flares
Eaton Front E-Locker
sawtooth1 is offline
post #4 of 18 Old 01-11-2011, 07:43 PM
Quoted: 27 Post(s)
What's the answer to this issue? My buddies 40k mile job 3 '08 is doing the same crap. Blows cold until you get up to about 80+ on the left side then it goes full hot. The right side controls fine. You can actually hear something that sounds like it's confused on it's position and is going back and forth back and forth in little incriments. It's very very frustrating.
Banshee365 is offline
post #5 of 18 Old 01-12-2011, 12:12 AM
amb82's Avatar
Feedback Score: 3 reviews
Just got mine back yesterday. It was doing something similar. It would blow hot air until you got down to 60. It blew hot or cold. no in between. They changed the blend actuators and seems to work fine for now. The mysterious morris code noise in my dash also went away
2010 F-250 Cabelas Edition
Sct with Gearhead tunes, 4" afe dpf delete exhaust, leveled on 22's
amb82 is offline
post #6 of 18 Old 01-12-2011, 04:47 PM
STROKER64's Avatar
08 6.4 been blowing ice cold on driver side no matter what temp is set at. Passenger side is perfectly fine. Went to dealer and it is the blend door actuator. Wanted $950 to fix it. Told em eat and I've dealt with it since then, which is extremely difficult in the winter especially with no floor heat! Anyhow, 99% sure this is what ur dealing with. What aggrivates me is that if there are so many people having this issue it must be a manufacturer defect and shoulda been warrantied or recalled in my opinion.
STROKER64 is offline
post #7 of 18 Old 01-12-2011, 06:10 PM
Quoted: 27 Post(s)
When by buddy get's his part I'll do a write-up with pics if anyone want's.
post #8 of 18 Old 01-12-2011, 06:18 PM
STROKER64's Avatar
That would be awesome and I know I would certainly appreciate it.
post #9 of 18 Old 01-20-2011, 12:17 PM
michigan37's Avatar
I had the exact same problem with my 08. They had to take the entire dash apart and replace the module for the TC. They tried 2 different times to fix it other ways and then finally replaced the whole thing and its been fine since.
08 F250 CC LB 4X4
Top Gun Customz Stabilizer
2.5" Newton lift w/ Bilstein 5100
Duratrac 325/60/20
20x9 Monsters
Firestone Ride Rite airbags w/ wireless control
Daily Driver
michigan37 is offline
post #10 of 18 Old 09-23-2011, 11:19 PM
has there been a write up on this? I am having the same issue on my 08 with less than 30K miles....Please Help
Twissted is offline
