Upfitter Switches - Ford Powerstroke Diesel Forum
6.4 Powerstroke Interior Discussion
post #1 of 18 Old 11-04-2010, 02:24 PM Thread Starter
Quoted: 45 Post(s)
Upfitter Switches
My 2010 F250 didn't come with the upfitter switches option, I got the useless coin slot... can you purchase and install the upfitters separately? Is it difficult?
RUFFSTUFF is offline
post #2 of 18 Old 11-04-2010, 04:33 PM
Sawed Off's Avatar
I've seen them for sale on ebay. As far as difficulty of installing them, im not sure on that
2010 SUPERDUTY
6.4 CREWCAB
Mods so far!!
Smoked Recon lights
Predator8 wheels
Toyo open country tires
Dpf/Doc delete
H&S tuned
S&B cold air intake
Sawed Off is offline
post #3 of 18 Old 11-05-2010, 03:48 PM
I have a set of switches for sale. PM if your interested. You'll need to get the harness from Ford about $100.
10' F350 CC SRW LWB 6.4, Green 4x4....stock for now.
Doozer is offline
post #4 of 18 Old 11-05-2010, 05:47 PM
i bought them for my 06 and installed them myself.... takes about 30 mins... very simple.... i didnt have to buy any harness though... it came with the relay box to mount behind the glove compartment and everything... definitely a good investment!
YFZ_53 is offline
post #5 of 18 Old 11-05-2010, 06:26 PM
valdez_oilburner's Avatar
I put them in my 09, hardest part was the plug in above the satellite radio box. Took about 45 mins to install. Fishing the plug thru the dash was not that fun either now that I think about it.
valdez_oilburner is offline
post #6 of 18 Old 11-06-2010, 06:23 PM
2008PSDnewbie's Avatar
Yup. You can buy them cheapest online.
Takes very little to install.
When you're installing the relay box, the front and side of the dash to the left of the steering wheel can come off.
The instructions I had only showed the front coming off. This will really help make it easier.
Glen
'08 F350, cc, lb, ARB front bumper, Warn 12,000 lb. Spartan tuner, KEM 310 tune
, Flow Pro 4", Weatherguard toolbox, 6" PIAA spots, leveling kit.
2008PSDnewbie is offline
post #7 of 18 Old 11-06-2010, 08:45 PM Thread Starter
Quoted: 45 Post(s)
Deal! Thanks!
So once you get it installed, the accessories you want to run off of it connect to the relay box?
post #8 of 18 Old 11-07-2010, 03:28 AM Thread Starter
Quoted: 45 Post(s)
2ND: Where is the connector in the dash for the switches' wire loom to connect to located?
Thanks all!
post #9 of 18 Old 11-08-2010, 03:43 PM
This helped me out alot.
There is a plastic plug in the dash harness that has to be removed first but it doesn't look like a plug. FYI.
Glen
post #10 of 18 Old 11-08-2010, 03:47 PM
Deal! Thanks!
There will be four terminated blunt cut wires on the harness coming out of the relay box. I think that they are explained in the document that I posted.
Definitely a worthwhile upgrade.
Glen
