Anyone added air to console or seats in a 2008? - Ford Powerstroke Diesel Forum
Old 07-11-2010, 09:55 PM
Have an 08 F350 CC 4x4.
Has anyone added air to the front seats?
Wandering if anyone has tried adding air vents to the center console so the backset has air?
Living in TX the 2011 is tempting to get just because of this but figured this can or has been done. I assume you need to source it from under the dash and run plastic tubes to the console.
Thanks for the input.
Old 07-12-2010, 12:44 PM
my 08 has air to the back,its under the front seats
Old 07-12-2010, 05:43 PM
My 08 has under seats as well but flow is light and only there when you split between dash and feet. If there was a way to have constant flow thru that vent I figure you can connect a 12v fan to an up-lifter switch and pull more air thru the vent...
