upliffter switches - Ford Powerstroke Diesel Forum
Old 12-29-2009, 04:44 PM
upliffter switches
has anyone added just the switch panel and took out the vent? can do my own relays an wiring. cost? thanks.
Old 12-30-2009, 04:13 PM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
You can get the whole kit on ebay for $150 or check with your dealer, they may beable to beat that price, I know mine was able to. Im in the process of adding them to my truck. I dont have a vent though, I had the dinky coin holder thing there.
Old 01-03-2010, 01:52 PM
Im new here but my truck came with the switches and I have wondered what they are for? They dont seem to be functional.
2008 F350 6.4
Old 01-03-2010, 02:46 PM
Thomas21, you can wire anything you want into those switches such as extra fog lights, high idle, gps, radar detector...ect. Anything that can be hardwired can be put on one of those switches if you want. From the factory they are installed, but all the wires you need to tie into to use the switches are under your hood/dash.
Old 01-08-2010, 11:05 AM
so u can install them in ur truck if u dont have them cause i was wondering about this cause i have that little coin thing there and i want the switches
Old 01-08-2010, 04:44 PM
Yes you can add them, I put the part numbers needed in the electronics section I think check it out.
Old 01-26-2010, 04:41 PM
2008 F350 6.4
I actually just wired a set of heated wiper blades and heated arms to my AUX4 switch and it worked like a charm. Much better than using the 12v 15amp switch they had supplied with the kit.
Keep in mind that each switch is rated for a different amp load.
Old 01-26-2010, 04:49 PM
Powerstroke Techie
....heated wiper blades?
Old 01-26-2010, 05:03 PM
<b>Premium Member</b>
Here's a question kinda on topic, I have a small cubby space below the trailer brake controller, and was wondering if a secondary switch panel can be put in there?
-BG06.
Old 01-26-2010, 05:16 PM
can you put the switches on and older series truck perhaps an 99 to 04
