Navigation units - Ford Powerstroke Diesel Forum
Old 11-07-2009, 08:47 AM
Navigation units
Does/can anyone give me the ford stok number for the oem navigation unit that comes in the 08 superduties??
Ebay has one with part number (7L2T-10E989-BB), would like to put one in the truck but want a plug and play and want to keep it OEM.
Thanks in advance
Old 11-12-2009, 03:08 PM
Thanks in advance
Cbenn, i do believe that thats the pn for the "4P nav DVD" that the unit uses for the navigational maps in its memory.
a pn that will work is 8L1T-18K931-CA this is a unit without chome trim.
Old 11-12-2009, 03:22 PM
here is an 07 pn with chrome knobs 7C3T-18K931-BG.
these will work from 04-08 as a plug and play unit. you will need the dvd map disc (8P is the newest version) and a GPS antenna (just double back tape it to the top of the metal frame under the dash when you got the radio out)
Old 12-16-2009, 10:39 AM
Do you know if a 2008 nav will work in a 2009? My father in law just picked up a 2008 nav with the ant. and disc and wants to put it in his 09. The 08 one has sync also.
Thanks Rick
Old 12-21-2009, 04:40 PM
Thanks Rick
it should be plug and play except for adding the gps antenna and you can just double back tape it on top of the metal bracing behind the radio
Old 01-16-2010, 04:48 PM
I would consider selling my so I can buy a new head unit. No clue what the stock unit is worth?
Throw out an offer via PM if you are still looking
