Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Powerstroke Interior Discussion
Old 10-30-2009, 07:49 PM
frankat1 frankat1 is offline
install nav unit
I have 2009 f250 with the sinc system ,backup camera in rear veiw, sat radio , sub, I think everything but the nav unit what would I need to get to install a factory nav unit besides the nav unit itself ?
Old 10-31-2009, 05:37 AM
Harley350 Harley350 is offline
You will need the unit itself (which may need to be programed unless it came from a Ford vehicle with all the options set to on (Rear view, Sync, audiophile, rear DVD and etc.) then it would be plug and play, if it's new or came without all options on it will need to be programmed. Possibly you will need a tee for the GPS antenna or maybe the plug is already there. The 09's have a combo GPS/SAT antenna unlike the 08's which have two antenna. If you want rear view in the unit there should be a plug for it next to all the others for the back of the unit.
