Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Powerstroke Interior Discussion
Old 09-23-2009, 05:56 PM
rodo rodo is offline
Outside temperature gauge
Anybody else not have one? I have a loaded truck except for the dual climate controls, so I do not have an outside temp gauge. For those without a factory unit...Have you installed anything aftermarket?
Old 09-23-2009, 09:16 PM
FX4STROKER FX4STROKER is offline
COTTONWOOD CREEK RANCH
Lick your finger and stick it out the window, Oh wait that's wind.
Yeah its dumb that you can buy a 50k truck that has powerfold mirrors but not a temp sensor. I bought this one somewhere on the net and put it in my old 08 f350. Its basically the one out of a chevy but its got direction and temp and the auto dim feature. The thing I really like on it is the light. its got two led lights on the bottom that light up and it does not light up the whole truck like the interior light does. it was really easy to install too
Old 09-24-2009, 05:58 AM
jeff_willis96 jeff_willis96 is offline
My 2009 displays the Exterior temperature on the Heater/AC display. I am pretty sure there is a button that toggles between interior and exterior temperature readings.
Old 09-24-2009, 06:13 AM
po-po 5.0 po-po 5.0 is offline
The '08 FX4s didn't have the auto-A/C so there's no display there.
Old 09-25-2009, 04:01 PM
dadriva dadriva is offline
Exactly what I am looking for!!!! (plus maybe a homelink option)
Do you have a link to where you found your mirror? Thanks!
Old 09-25-2009, 04:11 PM
Its been over a year since I bought it. I dont have a clue where I got it.
Old 09-26-2009, 07:30 PM
superdutydixie superdutydixie is offline
so it's Chevy right? and how did you hook it up and how hard was the install?
Old 09-26-2009, 07:50 PM
Yeah its pretty much a chevy mirror. Hook up is easy, I just hooked it up to a keyed ignition wire and then the temp sensor I ran through the fire wall and down along the frame rail and mounted it in the crack between the cab and bed. Here is a link to one just like it.
Gentex Auto Dimming Rear View Mirror With Compass Temperature and Lights
Old 09-27-2009, 04:37 PM
as6.4stroke as6.4stroke is offline
my truck has a ext button on under the climate control screen and i pressed it the other day and i think it read the outside temp i maybe wrong
Old 09-27-2009, 05:53 PM
jasonmt jasonmt is offline
The Ext button is going to be hard to find if your climate control looks like this:
