Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Powerstroke Interior Discussion
Old 08-03-2009, 08:11 PM
speckfisher speckfisher is offline
09' F-350 Temperature Adjustment
Does anyone know how to adjust the digital ext. thermometer on the a/c panel. For the past 4 days it has reading higher than the correct temp. This morning at 6:00 am it was reading 102 deg. Yesterday evening it was reading 101 when the actual temp. was 86 according to the weather channel at 7:00pm
Old 08-04-2009, 10:38 AM
Harley350 Harley350 is offline
I know of no adjustment. Maybe the tech can hook up his computer and change parameters but I doubt it. I would guess it's a bad temperature sensor unit and would need replacing.
Old 08-17-2009, 09:46 AM
po-po 5.0 po-po 5.0 is offline
If you live in a major city your temp gauge will never read what the weather channel says the temp is. The reason being: the weather normally pulls their temp readings from the top of their doppler towers............well above the "urban heating" effect. Your gauge pulls from behind the grille, only 5' off the ground, and is subject to reading extra heat radiating off the pavement.
Old 08-18-2009, 07:36 PM
Blk350on20s Blk350on20s is offline
Its a bad temp sensor. Happended to my 6.0. Head to the dealer and have them replace it.
Old 08-18-2009, 07:38 PM
bockhold bockhold is offline
broke college kid
Send a message via AIM to bockhold Send a message via MSN to bockhold Send a message via Yahoo to bockhold
it will prob mean that the earth is really HOT!!!
