Originally Posted by micky_blue
I would call kicker and see what size enclosure those subs want before I paid for them. Subs have a certain enclosure size that they operate best in. This has to do with the type of magnets used, size of voice coil(s), moving mass, even the displacement of the sub itself. I say that because if you put your subs in to small of a box they will be fast as hell and not go very low. To big of a box and they are slow and muddy. The right size box is very important. Now you said your have a cube behind each sub, does that take into account the displacement of the sub itself. When the sub is set into the enclosure it will take up some space so your cube is now .8 cubes. A trick is to get fiberfill (the stuff used to fill pillows) and pack it in there. Now you do not want it super tight but fill the box with the stuff. This acts as a bit of resistance and will make a box sound 10-20% larger than it is. This will also absorb the back wave off the speaker and give you a more crisp sound.
I'm not trying to sound like a wise A$$ but I did compete nationally in car audio years ago. That box you built is solid. Very good job with it. I just don't want all your labor to end up sounding bad.
micky
Thanks Micky. I built the box to have 1 cu/ft air space which is what the Boston's call for. Kicker recommends 1.25 cu/ft, but I believe I'll be close enough, worst comes to worst, I'll toss the kickers for something else if they don't sound up to par. I'll definitely be putting fiberfill in there
. This box is being built to jam the **** out to some good rock music, so the small enclosure should create some real tight explosive bass, perfect for what I'm listening to. Oh by the way, the whole truck is covered in two layers of Rattle Trap, or 200 sq.ft worth of the stuff.
