Hey guys, I have been running the 275 for a little over a week now. I have been very easy on it, I have just been getting some extra MPG from it first. I felt a sputter, and it felt like a slight ruff idle today, so I checked codes. I found two.
P2080 Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor 1 and P1000 On-Board Diagnostic (OBD) Systems Readiness Test Not Complete Does this mean I need to change one of the EGT sensors? Or is there another problem ![]() Any help, as always is greatly appreciated
Dont worry about the p1000 all of them do it,
The p2080 is probably your first temp sensor in the exhuast. make sure its hooked up good, otherwise it may need to be replaced, clear the codes and try it again if it doesnt come back i woudlnt worry about it. |
Well the code keeps coming back P2080 Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor 1
What sensor is this? Is this the very first one for sure? I think I am going to have to order one. If the CEL doesn't come on, is even necessary to change? Also, does anyone know the correct part #? Last edited by dieselkane; 06-08-2009 at 11:53 AM. |
Ya first sensor. I dont know if you NEED to change it but it might not hurt i dont know how much of the tuning is based off the sensors if any. I think that they are all the same part number but i may be wrong. I have two used ones sitting in my glove box out of a rolled truck and i think the part numbers are the same.
