P2452 Engine Light - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-20-2009, 01:00 PM Thread Starter
08FX4RBP's Avatar
Exclamation P2452 Engine Light
It came on right when the Regen cycle kicked on, seems like everytime i get in my truck the regen cycle kicks on and now its throwing this code.confused:
Any ideas on what is going on?
08FX4RBP is offline
post #2 of 16 Old 05-20-2009, 01:07 PM
Let's Run'em
TwinTurboStroker's Avatar
Quoted: 10 Post(s)
It is your pressure sensor on the exhaust down by the 3 EGT sensors
-Julian
4th 6.fo
TwinTurboStroker is offline
post #3 of 16 Old 05-20-2009, 01:09 PM Thread Starter
08FX4RBP's Avatar
what causes this?
08FX4RBP is offline
post #4 of 16 Old 05-20-2009, 01:10 PM
Let's Run'em
Quoted: 10 Post(s)
what causes this?
Any number of things, it could be just a bad unit, since you said your truck is going into regen, I'm assuming your truck is stock?
-Julian
4th 6.fo
post #5 of 16 Old 05-20-2009, 01:14 PM Thread Starter
08FX4RBP's Avatar
i have just a dpf back exhaust and a CAI
08FX4RBP is offline
post #6 of 16 Old 05-20-2009, 01:18 PM
Let's Run'em
Quoted: 10 Post(s)
What CAI are you running?
-Julian
4th 6.fo
post #7 of 16 Old 05-20-2009, 01:24 PM Thread Starter
08FX4RBP's Avatar
AFE.....had it on for like 1500 miles and no problem
08FX4RBP is offline
post #8 of 16 Old 05-20-2009, 01:30 PM
Let's Run'em
Quoted: 10 Post(s)
Well that very well maybe your problem. Some trucks it only takes 40 miles, some trucks its 400 miles, but the fact is that in most F250/350 6.4 trucks the AFE will throw a CEL with stock tuning. Most CEL's involve all the regen sensor, like the pressure sensor CEL your truck is throwing. Try this, until your ready to run a DPF delete tuner, put your stock intake on and see if the CEL goes off by itself, I'm betting it will . Now when you get a DPF/regen delete tune you can throw that AFE back with no problem
-Julian
4th 6.fo
post #9 of 16 Old 05-20-2009, 01:32 PM Thread Starter
08FX4RBP's Avatar
so a tune with the dpf on will not do a thing for it? It just seems that dpf is a piece of **** and makes more problems then what its worth.
08FX4RBP is offline
post #10 of 16 Old 05-20-2009, 01:36 PM
Let's Run'em
Quoted: 10 Post(s)
Don't know about a different tune that still enables regen and the DPF to be used. But if your going to tune the truck and void the warranty, why keep the DPF? If your going to do it, might as well go big and your right about DPF, its way more trouble than its worth
-Julian
4th 6.fo
