High Boost, Low Power
Need Help!
I bought a 2008 6.4 4x4, long bed in Sept 08. The truck has 16,600 miles on it and has rarley given trouble until now. I took it on a 3,000 mile trip. When I left, the truck was running great. On the way back, the boost was running around 25-30 psi while pulling a 7x16 enclosed trailer loaded with our hunting gear. My fuel mileage dropped to about 9mpg and the truck felt like it has a loss of power. Also, after driving at highway speeds, exiting of the interstate and starting again, the truck will not "go" when I step on the gas pedal (not in regen)! Now the boost gauge is almost always pulling 20 - 35 lbs of boost with no load. I have had it to the dealer with no luck! The SM tells me to not worry about the boost gauge "they all do that" and also said he contacted a Ford engineer who said that "it is typical for a diesel to lose power like that". I know neither one of these are correct. The truck is stock woth no mods, any similar problems or possible solutions? Thanks Andy |
so perhaps try a different dealer. I had a dealer that was worthless, and then I switched to one that was closer, and had a dedicated truck shop so they really know what they are talking about.
Have them check out your dpf...might be getting clogged.
Thanks for the info. I'll give it a try!
Spartanize it and drop the DPF
Was it raining or humid? If so have them do the TSB for the lack of power / white smoke on mod to heavy tip in after driving 20+ mins.
Mine is scheduled for next Tuesday for this fix. |
Re: Landshark
Thanks Landshark, do you have a TSB number?
Sorry, do you have a TSB number or should they know what I am talking about?
It did happen when it was raining but it has happened a few times during dry weather! |
TSB 08-25-1
