6.4l recalls
There are a few open recalls on the 6.4L engine one in which will aid in the "Radiator issue" that everone has experienced. This installs a venturi Tee into the cooling system.
the second is a pcm reprogram that will help with shift quality - regen notification on instrument cluster - and slight drivability issues. If you are not sure if these recalls effect your vehicle feel free to contact me and I can run your VIN number to check for recalls. I can also assist in scheduling your truck for the recalls to be perofrmed. Approx 70% of the trucks I have seen for recalls have had leaking radiators. Protect your engine - it runs hot, it breaks. San Tan Ford is located in Gilbert Arizona. Josh Valentine Commercial Fleet Service Advisor San Tan Ford joshvalentine@santanford.com |
![]() All of us here appreciate input from another dealer. |
since the pcm reprogram my truck is "cleaning the exhaust filter" every 300 miles, dealership is telling me this is now normal and I should get used to it. I drive highway miles, no stop and go, seems excessive to me (and fuel economy has dropped almost 3 mpg).
I am heading to the dealership on monday was told have a few things they need to do due to recall on my truck.......
300 highway miles sounds about right for regeneration cycles.
Every since the dealer ship has done all the recalls on my truck the fuel mileage drop for 14.5 to 13.2, and that is were it stay's.
Welcome to the ORG, Josh! Glad you found your way over here and appreciate you sharing this information. I'm in Arizona as well. Maybe you can join us for a get together we are planning as part of the Arizona Powerstroke Group (APG) Just a bunch of folks getting together and having a good time.
Has anyone had a ticking/crackling noise from the lower part of the engine? Sounds like exhaust is cooling done after the engine is off, but i hear the noise while the engine is running and more when i rev it up.
anyone else have these issues My truck is an 08 f250 Lar. 6.4 lit engine 1500 miles thanks |
same thing with mei hace 13000 miles its gotta be just the exhaust no big deAL ...im new to the 6.4 .. but im already liking it better than the 6.0
Just an update, in looking for an aftermarket radiator for my 08 6.4L since 3 radiators in 61,000 miles is unacceptable in my book and only one of them warrantied by Ford, I contacted a radiator shop who informed me that Ford is in the process of generating a recall on the radiators. Save or dig out your reciepts and hang on for your reimbursment.
Hope this helps. |
