2008 F250 injector problems.. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-12-2014, 10:28 AM Thread Starter
First post on here! I recently got a 2008 F250 powerstroke crew cab with 166k miles. When it goes into regen mode it lets out a ton of white smoke!! i had a friend run some codes on it with the snap on scanner and it shows that my injectors are way off from "0" Is there anything i can do besides getting them rebuilt so they will run at "0" mainly worried about injector 2 and 3.
#1 is 0
#2 is +8
#3 is +9
#4 is -3
#5 is 0
#6,7,8 are all -3
40-GIN is offline
post #2 of 4 Old 05-18-2014, 06:50 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
It's possible you have 2 failing injectors. I would be on the lookout for metal in the fuel honestly. I have seen this more often than not when 3 or more injectors start going way out on short fuel trims.
Any base engine concerns like worn out rocker or washed out cylinder walls will also cause fuel trims to go out of normal range.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 4 Old 05-30-2014, 05:00 AM
I understand why you dont want metal in there. Why would injecors if they are failing like you mentioned, three or more cause metal? Thx.
2008 6.4 f250 lariat 4wd
melmount is offline
post #4 of 4 Old 05-30-2014, 06:08 AM
Quoted: 7 Post(s)
The failing injectors themselves won't cause the metal, however any metal in fuel system from say a failing high pressure fuel pump will definitely cause injectors to fail.
tofer is offline
