HELP!!!!! - Ford Powerstroke Diesel Forum
post #1 of 27 Old 05-04-2014, 09:15 AM Thread Starter
theplumbingmedic's Avatar
HELP!!!!!
I am out of town (not too far) I was driving under acceleration and the tranny downshifted and then upshifted and started throwing white smoke deltas are 12 . Ran a check and i have codes : PO 275 ,PO278, PO305. Engine runs rough on idle. I am ascared!!!! Any help is much appreciated
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #2 of 27 Old 05-04-2014, 09:35 AM Thread Starter
Any feed back would be appreciated i am freakin out
exhaust
post #3 of 27 Old 05-04-2014, 09:56 AM Thread Starter
Anyone ? Please i really could use a hand here
exhaust
post #4 of 27 Old 05-04-2014, 01:58 PM
The p0275 is a contribution code/injector cyl 5. P0278 is cylinder imbalance #6. And p0305 is a misfire cyl #5. Sounds like you have a bad injector to me. How many miles on the truck? I'd avoid driving it or you could possibly have that injector hang open and melt the piston or grenade the motor. Either way bad news.
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
post #5 of 27 Old 05-04-2014, 02:20 PM
Sounds like exactly what happened to mine, won't know for sure what it is until I get it in but everything I have read and everyone I have talked to has said sounds like a hole in the piston or cracked piston. If I pull the dip stick while it's idling it has lots of blow by.
Alaskan_awd is offline
post #6 of 27 Old 05-05-2014, 03:22 AM Thread Starter
Thanks guys...... It has 48500 on it. I`m going to bring it back to stock this week and have it towed into the dealership.I will check blow by via the dipstick when i put everything back on.
exhaust
post #7 of 27 Old 05-07-2014, 07:50 AM Thread Starter
Well it went to the dealer and the motor is cooked
exhaust
post #8 of 27 Old 05-07-2014, 07:52 AM Thread Starter
The dealer is doing it under warranty
exhaust
post #9 of 27 Old 05-07-2014, 10:07 AM
Quoted: 2 Post(s)
mike... melted piston from hung injector? cracked piston?? what was it?
you should have them install ARP studs when they put the heads back on!
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #10 of 27 Old 05-07-2014, 10:13 AM
You've had the H&S tuner installed since 2011?
Glad to see the dealer taking care of you on this.
DisposableHero is offline
