Smoking constantly, P0281, Running Rough, bad juju! - Ford Powerstroke Diesel Forum
post #1 of 22 Old 05-01-2014, 10:03 PM Thread Starter
Ok guys,
I got on it a little on the highway today, not much was not WOT, something blew, and then she started smoking.
It will start right up but idles extremely rough, like one of the cylinders is not firing (p0281 cylinder #7 contribution/balance).
If I pull the dip stick it smokes/huffs so there is bad blow by apparently?
This happened very suddenly. Possible causes and possible cost?
Alaskan_awd is offline
post #2 of 22 Old 05-02-2014, 07:15 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Sounds like it might be a cracked piston
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
The Following User Says Thank You to 04hdfatboy For This Useful Post:
Alaskan_awd (05-02-2014)
post #3 of 22 Old 05-02-2014, 08:01 AM Thread Starter
That's what I was afraid of, so forget an arm & a leg, just take the entire torso? What is the cost on that typically?
post #4 of 22 Old 05-02-2014, 08:13 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I asked Midwest diesel one time out of curiosity and he quoted me around $5,000. Hopefully its something else but if there is that much blow by its probably a piston.
08 F350 cc/sb 4X4
post #5 of 22 Old 05-02-2014, 02:53 PM Thread Starter
Ok thanks, I don't think I'll even bother with return to stock/warranty, I'll just pony up and have them do studs/gaskets while it's open. Anything else I should have done while it's opened up?
post #6 of 22 Old 05-03-2014, 07:22 AM
groove's Avatar
How many miles on the truck?
08 F350 CCSB 4x4 01/07 Job 1
0.030" de-lipped slugs, 70+ atmosphere turbo, ARP studs, Mild Ported Heads (w/bronze guides), Flo-Pro EGR Delete
Mini Maxx Race tuner, AFE exhaust turbo back, S&B Intake, Sinister coolant filter
Lifted nicely on 20" wheels
groove is offline
post #7 of 22 Old 05-03-2014, 04:28 PM Thread Starter
Only about 65k
post #8 of 22 Old 05-05-2014, 09:09 PM Thread Starter
Ok, so tomorrow I'll be calling the performance shop for a few estimates (they don't have the truck yet, but we are assuming hole in piston + getting new studs + maybe the new SCT Live Wire so I can check all my stuff). After I get a cost estimate, if it falls within my range I am thinking about having them throw in an Elite 71mm LP turbo, 6.0 manifolds, waste gate, bov, and maybe some new intake piping. Any thoughts?
post #9 of 22 Old 05-06-2014, 01:32 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Ported intake manifold and new oem lifters. Also updated hoses if they are the old style. Also new tensioners, idlers and belts.
08 F350 cc/sb 4X4
Alaskan_awd (05-06-2014)
post #10 of 22 Old 05-06-2014, 04:52 PM Thread Starter
Wow, I don't know what to do at this point, I'm going to have to try for warranty. I called the shop, they said $13k to rebuild or $20k for a new motor. Does that sound right? $13k assuming it only lost a piston?
