Blowing a little blue smoke and jerking under load..? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-01-2014, 12:07 PM Thread Starter
PowerstrokeRyan302's Avatar
I pull about 24k lbs everyday. Yesterday I turned at a stop sign and immediately had to climb a decent hill, started blowing blue smoke out exhaust and truck was jerking/lunging real bad till I stepped in the pedal a little harder. Did it again today.. Be honest.. How bad is it? Injectors or what..?
2010 F350 DRW. Currently bone stock
PowerstrokeRyan302 is offline
post #2 of 9 Old 05-01-2014, 12:08 PM Thread Starter
Truck is bone stock
post #3 of 9 Old 05-01-2014, 12:57 PM
TwinTurbo6.4's Avatar
Quoted: 82 Post(s)
Is it a constant blue smoke or in regen, dpf deleted or no?
'08 F250
H&S Mini Maxx w/ Cale Thompson tunes, FloPro 5"/EGR Delete/Cold Side Pipe, Pillar Gauges and CTS2,
Gear Alloy Big Blocks 20x12 -44, RetroFit Headlights - Morimoto Mini H1's
TwinTurbo6.4 is offline
post #4 of 9 Old 05-01-2014, 01:05 PM Thread Starter
Constant only while its under a load going up a hill or something. Only does it from a stop to uphill. Not if I'm already cruising and go up a hill. When its under heavy load.. Jerks and struggles and blows blue smoke. Not DPF deleted, and didn't do it during regen
post #5 of 9 Old 05-01-2014, 02:16 PM
Quoted: 82 Post(s)
Could be a number of things. Bad DPF, bad fuel EGR, underfueling on an injector. Any codes or anything?
'08 F250
post #6 of 9 Old 05-01-2014, 02:22 PM Thread Starter
No codes. That's what's weird
post #7 of 9 Old 05-01-2014, 02:24 PM
Quoted: 82 Post(s)
I hope it's just a case of bad fuel. Do you run any fuel additives? Also, how cold is it where you are?
'08 F250
post #8 of 9 Old 05-01-2014, 02:26 PM Thread Starter
I have run a couple tanks of DieselKleen and I'm in TX.. it's never cold haha
post #9 of 9 Old 05-01-2014, 02:28 PM
Quoted: 82 Post(s)
Ah, gotcha on that one. That's what I run as well. I'd ride it out to see if it is just bad fuel.
'08 F250
The Following User Says Thank You to TwinTurbo6.4 For This Useful Post:
PowerstrokeRyan302 (05-01-2014)
