best egr delete fpr 6.4 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-30-2014, 08:59 AM Thread Starter
i had 2 6.4 trucks that were both dpf deleted. they are both 2008 models. the first truck blew the bottom half of motor b/c of faulty egr. i still have the second 6.4 and i want to know what the best egr delete is. the first truck had 112,000 miles, this truck has 57,000 miles on it. am i correct in thinking an egr delete along with a dpf delete and routine main. can prevent the second motor from coming apart?
madeline is offline
post #2 of 5 Old 04-30-2014, 10:02 AM
hoofdoctor's Avatar
""""am i correct in thinking an egr delete along with a dpf delete and routine main. can prevent the second motor from coming apart?""""
My vote would be Sinister........and to answer your second question IMO..........
This is the #1 reason why I did the deletes. I want my motor to last a long time! There was a great post a while back with video of why the 6.4 deletes are the best option for these trucks.
My #2 reason was fuel economy.
And #3 It turned my once tame 6.4 into a MONSTER. I had no idea how much power there was to be unleashed!
SCT 5015 Livewire TS....... Diamond Eye 4" Pipe Cat deleted.........EGR DPF Deleted....... Sinister Intake Elbow........ S&B Cold Air Intake.......
hoofdoctor is offline
post #3 of 5 Old 04-30-2014, 10:51 AM
superduty6.4's Avatar
Whichever EGR delete kit you go with make sure you get the one that includes the intake elbow. They all pretty much serve the same purpose. I don't think there is much if any gains from one to another. Some are cosmetically more appealing. As long as you go with one of the well known brands like sinister or flo-pro I'm sure you will be fine. I'm sure someone will correct me if I'm wrong.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #4 of 5 Old 05-01-2014, 08:25 AM Thread Starter
thanks, i will get it done. the first truck was an expensive lesson.
madeline is offline
post #5 of 5 Old 12-16-2014, 02:10 PM
shmeldon22's Avatar
I am about to do the same on my '09. I have an Edge CTS tuner I got with the DPF delete 3 years ago. Can I use this tuner or do I need an H&S or Spartan?
shmeldon22 is offline
