6.4 with a 242b code? any help please - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-26-2014, 02:20 PM Thread Starter
what is a 242 b code?
mac55 is offline
post #2 of 4 Old 04-26-2014, 03:04 PM
Trouble code help - Diesel Forum - TheDieselStop.com
P242B 1PC
Exhaust Gas Temperature
Sensor Circuit Range/
Performance Bank 1 Sensor 3
This error occurs if the EGT3 temperature sensor signal
in the exhaust at key on, following an 8-hour soak, is
significantly different than ambient temperature
Alaskan_awd is offline
post #3 of 4 Old 04-27-2014, 07:19 AM Thread Starter
So if the day before I drove 300 miles to and from some where and the next day I drove like 10 miles this could happen?
mac55 is offline
post #4 of 4 Old 04-27-2014, 09:44 AM
From reading the above, my guess is, the truck expects the EGT sensor to read the same as the ambient temperature after sitting for at least 8 hours. Yours is either reading higher or lower then ambient temperature so your EGT sensor is probably bad. That's my best guess.
The Following User Says Thank You to Alaskan_awd For This Useful Post:
mac55 (04-27-2014)
