6.4 Durability Advice - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-26-2014, 08:53 AM Thread Starter
Got a 2007 6.4 in the shop with 113,000 miles. Had very low compression in most of the cylinders.
Pulled cab and intake. The intake valves are leaking badly. Other than that everything else seems to be fine. Is there something like the valves coking up so badly that eventually there is a no start?
Anyways, we are doing ARP studs, and EGR/DPF delete. Is there anything else recommended at this point. I am not looking for top power but rather reliability and efficiency.
Are the 6.4 oil coolers not an issue like the 6.0's?
What about injectors?
delmer is offline
post #2 of 9 Old 05-07-2014, 05:14 PM
OelMotor's Avatar
If you want to improve the odds of long term success, you should look into o-ringing the heads. The heads must be checked for straightness beforere- installation.
Good luck with it and keep us posted.
Doc
ASE Master (expired)
Diesel Lover
OelMotor is offline
post #3 of 9 Old 05-07-2014, 06:08 PM
I would add a set of up pipes from RCD or Rudy's why the cab is off. Stock up-pipes are known to crack especially if you are going to run a 250+ tune. Have not read about a lot of 6.4s having oil cooler issues.
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
post #4 of 9 Old 05-08-2014, 02:17 AM
OelMotor's Avatar
Delmer,
Was it turned up with a tune or stock?
Doc
Diesel Lover
OelMotor is offline
post #5 of 9 Old 05-08-2014, 02:54 AM
Pyro1's Avatar
I agree, just replaced my up-pipes with the HD ones from Rudy's.
2008 F350 King Ranch 4x4, 6.4L DFP & EGR delete,Jasper Engine with Head Studs, Mishimoto Radiator, DashDAQ xl & Spartan Tune, S&B cold air intake,No Limit Intake Elbow, open from the turbo back
Pyro1 is offline
post #6 of 9 Old 05-12-2014, 08:14 PM
groove's Avatar
Not sure you need to O-ring the heads just for reliability. A good re/re on the heads (make sure they are flat), prep the block and install FACTORY head gaskets and ARP's and I would consider it done. Up pipes are known to go, mine are stock but its on the things to build for a rainy day list. If you have the heads off, may as well do lifters, push rods and rocker arms. None of these are really all that expensive, and are easily replaced heads off.
Just my 2 cents
08 F350 CCSB 4x4 01/07 Job 1
0.030" de-lipped slugs, 70+ atmosphere turbo, ARP studs, Mild Ported Heads (w/bronze guides), Flo-Pro EGR Delete
Mini Maxx Race tuner, AFE exhaust turbo back, S&B Intake, Sinister coolant filter
Lifted nicely on 20" wheels
groove is offline
post #7 of 9 Old 05-13-2014, 04:28 AM
Quoted: 48 Post(s)
don't o-ring the heads. I would definitely do lifters and an oil cooler while it's apart
drunk on diesel is offline
post #8 of 9 Old 05-18-2014, 05:53 PM
Powerstroke Techie
Quoted: 17 Post(s)
Garage
Feedback Score: 4 reviews
intake valves? really? you better look a little deeper or you're going to regret it. How do the cylinder walls and piston rings look?
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #9 of 9 Old 05-19-2014, 03:22 AM Thread Starter
Ok an update. We bought this truck not running and after someone had spent $$$$ at Ford on it.
We took the heads off and they were leaking badly. Got them rebuilt by Noland Head.
We also sent injectors off to be tested and discovered 6 out of 8 had zero flow.
So we replaced HPFP and injectors with Ford remans. Replaced lifters and rocker arms.
ARP studs, EGR and DPF delete. CAT coolant, FASS LPFP. CTS Livewire programmer.
Thing runs like a scared rabbit.
Now it is for sale.
delmer is offline
