Where the f*ck is my coolant going? - Ford Powerstroke Diesel Forum
post #1 of 59 Old 04-19-2014, 09:13 AM Thread Starter
sanman28's Avatar
Ever since i had my cab off, ive been topping my coolant reservoir every two or 3 days with 1/2-1 gallon of water. The dealer said they pressurized it for 3 hrs and couldnt find anything. I see no drips either. Oil looks great, truck runs great. No codes. Fully deleted of course. Where is it going? WTF?
2010 CCSB FX4. Mini Maxx/Gearhead, Deletes, H11 Studs, Up-pipes, 4" DP, 5" Back, CAC, Elbow, CCV, CAI, Custom Heads, Elite Transmission
FBHO
sanman28 is offline
post #2 of 59 Old 04-19-2014, 10:32 PM
Send a message via Yahoo to Krazzyoddee
Did they test the puke bottle cap? Might be losing it out the cap. Only bout $5 for new one and the factory ones almost always go bad and won't hold more than 4 psi. New one should hold up to bout 18
2004 f250 king ranch ranch hand front and rear bumpers fx4 crew cab 6.0 all stock except egr delete and 4" straight exhaust.
Krazzyoddee is offline
post #3 of 59 Old 04-20-2014, 04:59 AM Thread Starter
sanman28's Avatar
The reservoir cap? For $5 ill get one.
FBHO
sanman28 is offline
post #4 of 59 Old 04-20-2014, 06:25 AM
Just a simple place to start also might check reservoir They have been known to crack or get holes in them
post #5 of 59 Old 04-20-2014, 06:31 AM Thread Starter
sanman28's Avatar
I would have thought the pressure test would have produced a leak in the reservoir. I suppose its possible the rattle and vibrations of driving around are what it takes to leak.
FBHO
sanman28 is offline
post #6 of 59 Old 04-21-2014, 07:35 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
A pressure test should reveal any external leaks I would think. Is your oil level rising?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #7 of 59 Old 04-21-2014, 08:34 AM
Here was my culprit for coolant going MIA
[IMG][/IMG]
Mavic19 is offline
post #8 of 59 Old 04-21-2014, 11:04 AM Thread Starter
sanman28's Avatar
Oil level looks ok i guess. I dont see any milk or anything. Ill keep an eye on its level if the new cap doesn't solve the problem.
FBHO
sanman28 is offline
post #9 of 59 Old 04-21-2014, 02:53 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
When you change your oil have a UOA done to see if there is coolant in the oil.
08 F350 cc/sb 4X4
post #10 of 59 Old 04-21-2014, 04:32 PM Thread Starter
sanman28's Avatar
Would that mean cracked head?
FBHO
sanman28 is offline
The Following User Says Thank You to sanman28 For This Useful Post:
troyford417 (07-15-2014)
