Need help, new to 6.4's - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-18-2014, 02:22 PM Thread Starter
Flaboystrokin's Avatar
Exclamation Need help, new to 6.4's
i just bought a 09 f250 6.4 with 110,000 miles and 4200 engine hours last wednesday.
just today i noticed that at an idle, every once and while, it seems to misfire. like how you have a fouled plug on a gasoline engine. no driveability issues, no ck engine light, no other problems. i called my ford certified diesel guy, he said "its nothing to lose sleep over. it happens every once and awhile and it could just be since you reflashed the PCM with the tune the driver on the injector is re-learning" does that sound like a possibility to you guys?
2009 F-250 Lariat FX4
-FLO-PRO 4" downpipe back with 6" mbrp tip
-Sinister EGR delete
-S&B intake
-H&S Mini Maxx, MCC tuned
-LED headlights
-20x12 fuel mavericks
-305/50 420's
Flaboystrokin is offline
post #2 of 6 Old 04-19-2014, 08:03 AM
superduty6.4's Avatar
Could you post up a video of it? May be nothing but a video might help.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 6 Old 04-19-2014, 08:11 AM Thread Starter
it hasent happened since yesterday afternoon so im guessing it was just a fluke, haha you couldnt tell via video anyhow, i felt it in the seat and very slightly on the tach when it would happen.however, after driving to work this morning ive noticed the truck to surge while under a light load, around 2,000-2,500 rpm's. im running rudy's diesels tunes on the truck now but just recieved IDP xtreme street tune for my truck. going to load it up when i get home and see if the surging goes away. i did some reading up this morning on that condition and most say its due to an issue with the tune that causes the surging problem.
-S&B intake
-LED headlights
-305/50 420's
post #4 of 6 Old 04-19-2014, 08:16 AM
I would imagine then if it was barely noticeable then it must be fine. About the surging I would agree that maybe reloading the tune might fix that. If not try and reload another tune and see if that helps. Sometimes certain tunes cause weird little issues
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #5 of 6 Old 04-19-2014, 12:10 PM
Quoted: 48 Post(s)
Shouldn't happen at all. Most likely am injector dropping out when the AC compressor cycles on.
Have somebody watch the power balance for you in order to figure out what injector it is
drunk on diesel is offline
post #6 of 6 Old 04-20-2014, 11:02 AM Thread Starter
well i figured out the surging issue, and the slight miss was due to the tunes that were preloaded on the livewire TS from rudys diesel. i ordered a tune from eric yesterday and installed it on my truck. and the issues are now non existiant. as for the injector possibility i will have a power balance test done a.s.a.p. just to be sure that all my injectors are in good shape
-S&B intake
-LED headlights
-305/50 420's
