6.4 sounds like its sucking air - Ford Powerstroke Diesel Forum
post #1 of 17 Old 04-13-2014, 09:38 AM Thread Starter
my 6.4 sounds like its either sucking or blowing air when I accelerate under a load, and I have virtually no turbo boost. EGR and DPF delete with SCT tuner. HELP
sgwjmstx is offline
post #2 of 17 Old 04-13-2014, 09:59 AM
Sounds exactly like my problem. See my post in another section, here's the link:
Full DPF and EGR delete - suddenly some sort of exhaust leak
Lots of good advice there. Good luck
mhutch2 is offline
post #3 of 17 Old 04-13-2014, 10:16 AM Thread Starter
where is the up pipe, any pics anywhere you know of?
sgwjmstx is offline
post #4 of 17 Old 04-13-2014, 10:28 AM
Here is a pic of the engine with the cab lifted. The rusty looking pipe you see on right of the pic is the driver's side up pipe that runs from behind the turbo to the EGR cooler. When you delete the EGR the pipe is no longer supported and tends to crack at the bellows. That's what happened to mine.
Apparently, one can remove that pipe and relocate the EBP sensor, however, I can't seem to fit my hands back there so there must be a trick to it.
Name:	powerstroke engine.jpg
mhutch2 is offline
post #5 of 17 Old 04-13-2014, 03:02 PM
sanman28's Avatar
This happened to mine too. Whistle noise under load and higher RPM's.
2010 CCSB FX4. Mini Maxx/Gearhead, Deletes, H11 Studs, Up-pipes, 4" DP, 5" Back, CAC, Elbow, CCV, CAI, Custom Heads, Elite Transmission
FBHO
sanman28 is offline
post #6 of 17 Old 05-24-2014, 05:22 PM
I had a dpf delete on my 08 last sept. I am now experiencing this sucking sound. I sounds like its coming from right behind the turbos.
2008 F450 w/Century 311. DPF/EGR delete. Spartan tuned.
2003 Grand Marquis..some mods...
jasong145 is offline
post #7 of 17 Old 05-24-2014, 06:09 PM
JD_MILLS's Avatar
Could be the up pipe leaking. Check around the firewall it'll probably have soot on it if they are. Mine was covered when my left one went out.
2008 f-250 LARIAT, SCT LIVEWIRE, S&B CAI, 8" MBRP STACK
JD_MILLS is offline
post #8 of 17 Old 05-25-2014, 12:03 AM
Seems when im cruising and there is low boost there's barely any noise. As soon as I build boost thats when I hear the air noise. Bad pipe?
post #9 of 17 Old 05-25-2014, 01:14 AM
mprc911's Avatar
My 6.0 was doing the same thing. Had a 6 inch crack in the plastic pipe from the intercooler to the intake elbow.
mprc911 is offline
post #10 of 17 Old 05-25-2014, 02:05 AM
So heres the question...is any harm done if I drive like this for a bit? The truck is driving fine. Just the pshhhhh noise
