connecting rod - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-02-2014, 03:18 PM Thread Starter
connecting rod
has anyone ever just change a rod after it bent. A customer brought a 6.4 with a blown injector and hydro-locked the cylinder and bent the connecting rod.
troym28 is offline
post #2 of 3 Old 04-02-2014, 03:34 PM
Quoted: 5 Post(s)
I have on my 7.3, but what caused it? Any damage other than that? The rotating assembly should be balanced after. I would weigh the old rod and the new rod and if its the same you should be alright. Are you sure its bent? I assume you have it apart.
2002 f250 ccsb 4x4, 250/200's,5 inch mbrp,itp boost fooler,regulated return/race fuel system, s&b intake, billet 4r100, swamps idm, lifted 2 inches, leveled, 35inch nittos on 18" s468, mishimoto intercooler, hydra tuning, detroit locker rear, dynomat, not done.........
2006 f350 ccsb 6.0, sct tuner 3015 custom tunes, studded, deleted, exhaust
mastertech79 is offline
post #3 of 3 Old 04-02-2014, 03:51 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 331 Post(s)
Ya i've done it a couple times. I put 8 in a 6.0 once cause someone got a little "ether happy" trying to make it run.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
