Losing coolant, no leaks, oil looks great. - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-29-2014, 02:13 PM Thread Starter
sanman28's Avatar
Im losing coolant. Cant find obvious leaks, oil looks great, and truck runs fine. Must be losing it while on the road. Is only way to test stationary with a pressure system?
2010 CCSB FX4. Mini Maxx/Gearhead, Deletes, H11 Studs, Up-pipes, 4" DP, 5" Back, CAC, Elbow, CCV, CAI, Custom Heads, Elite Transmission
FBHO
sanman28 is offline
post #2 of 9 Old 03-29-2014, 04:59 PM
Use a flashlight and look at the upper and lower radiator hoses, where they connect to the engine. look for white crust , thats evidence of a leak. If the connections at the engine side of the hoses are black plastic, instead of white/yellowy plastic, then its prolly radiator hoses leaking. The black plastic tips are an outdated single-o-ring design. Also, look at the radiator at the bottom, on the driver's-side corner. Thoses 3 things account for like 95%+ of coolant leaks on these trucks.
Scumbag is offline
post #3 of 9 Old 03-30-2014, 07:17 AM Thread Starter
sanman28's Avatar
F*ck......think i just toasted my transmission. Just what i need. 40k miles with a tune and a heavy foot has been bad.
FBHO
sanman28 is offline
post #4 of 9 Old 04-28-2014, 05:08 PM
TxBoyJay's 08 KR250's Avatar
ok?? so what was the cuase of you losing coolant?? i'm having the same prob..i had to put 2.5gals into my resevoir 7days ago just to get it to the cold line, and now i'm down to loooow..
W.D.K / South Texas Coal Rollers
2008 f250 CCSB 6.4 King Ranch RoLLn on 35's
Bully Dog CAI
4in Flo-Pro DPF-D TBE 6in Tip
R.C.D Intake elbow / Cold Side IC Pipe *Lime Green*
SCT 3015r Quick Tricks Looney Street Tune "Tnx Vivian"
5k HID's
LED DOME/L.PLATE LIGHTS/LED fog replacement bulbs
30in LED Light bar
Bully Dog Watch Dog Monitor
4in TUFF LED Fogs
Find me
on FB-TxBoy Powerstrokin Martinez
New DD^ 03 GT Vert
TxBoyJay's 08 KR250 is offline
post #5 of 9 Old 04-28-2014, 05:13 PM Thread Starter
sanman28's Avatar
Dont know. Going in on wednesday to hopefully find out. Ill be mighty pissed if they installed my head studs on bad gaskets and didnt notice.
FBHO
sanman28 is offline
post #6 of 9 Old 04-28-2014, 05:20 PM
ya, that'd be pretty crappy... ok well let me know, i might just take mine in to the dealer also..
Bully Dog CAI
5k HID's
30in LED Light bar
4in TUFF LED Fogs
Find me
New DD^ 03 GT Vert
post #7 of 9 Old 04-28-2014, 05:27 PM Thread Starter
sanman28's Avatar
Ill update.
FBHO
sanman28 is offline
post #8 of 9 Old 05-03-2014, 07:35 AM
well i took my truck into the dealer and they said my upper / lower rad hoses need to be updated and my radiator has a leak... idk how it has a leak but not visibly leaking..
not the head gasket or water pump.. about $2,150 to replace rad and hoses, dugas bottle n hose plus the fluids.. the price for the oem radiator is $800. so at that price i might just go buy an aftermarket and do the work myself..
Bully Dog CAI
5k HID's
30in LED Light bar
4in TUFF LED Fogs
Find me
New DD^ 03 GT Vert
post #9 of 9 Old 05-03-2014, 08:04 AM Thread Starter
sanman28's Avatar
Mine was head gaskets
FBHO
sanman28 is offline
