New to diesel world plz help - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-26-2014, 05:48 AM Thread Starter
Hello everyone. I am new to the diesel world and need some help. I bought my first diesel vehicle recently, an 08 F350 xlt drwd. The following codes came up when I hooked up the scanner to it.
P0684-Glow plug control module
P0420-o2 sensor or cat
P2002-dpf bank 1
P2452- ?????
What would cause these codes to go come up and what can I do to correct them? Also from time to time, my truck will let out white heavy smoke from the exhaust. It comes and goes. I've heard that diesel trucks smoke sometimes but I don't think what my truck is doing is normal.
And last but not least, wiring fault on trailer message. How can I correct that problem. Thanx in advance. Any help will be greatly appreciated.
Sxeautoworx is offline
post #2 of 3 Old 03-26-2014, 05:51 PM
Tbcm fault is usually from dead batteries or a bad tbcm that doesnt light up. That smoke is regen and is normal on a 6.4.
The glow plug module code is a bad gpcm or a halfazz plugged in connector, you gotta push hard to plug them in.
The other dtcs are prolly from a bad dpf pressure sensor, hose to sensor is broke, or harness side connector pigtail, more likely the pigtail connector pin fitment. Which may be contributing to irregular regens.
Scumbag is offline
post #3 of 3 Old 03-27-2014, 05:22 PM
sanman28's Avatar
Your good.
2010 CCSB FX4. Mini Maxx/Gearhead, Deletes, H11 Studs, Up-pipes, 4" DP, 5" Back, CAC, Elbow, CCV, CAI, Custom Heads, Elite Transmission
FBHO
sanman28 is offline
The Following User Says Thank You to sanman28 For This Useful Post:
Scumbag (03-27-2014)
